Originally posted by: steve22
Originally posted by: jagfan
For all you 3200 owners out there, I was successful in modifying the files so that the map is on the main drive and the 6M POI file is on the SD card. Without the SD card, the unit WILL map but fail in doing POIs. With the SD card, the unit will both map and do POIs.
Will you tell us how you accomplished that?
First, credits to Timekeeper and dgoeken for sharing their information and expertise. Before starting, backup your 3200.
1. Get the 6M POI file using Timekeepers instructions on the first post of this topic.
2. Create a MAP subdirectory on an SD card (I used a 2G)
3. Copy the 6M POI file (US48_POI.POI) to the MAP subdir on SD card
4. Copy the following 3 files from the 3200 to the MAP sudirectory on the SD card:
Index.mct, NRBM_NA.MGI, and US48.IMI (Do not delete them from the 3200).
5. Edit the Media.cfg file on the 3200 so that #POI Map Data points to
\SDMMC Card\Map
6. When the 3200 is disconnected, it should reset automatically. If not reset with paperclip.
7. Without the SD card inserted, 3200 should map but not POI.
8. Insert SD card and reset with paperclip - 3200 should now map and POI. Anytime you remove SD card while 3200 is on, the unit will need to be reset when the SD card is re-inserted. If SD card stays in unit, you can turn it off and on at will and it will map and POI.
I plan to keep the SD card in the 3200.
