Rock Hydra
Whoa...steady there killer. You're almost pushing 3 MHz...Too bad my Gameboy is more powerful. No LL Ram, memory dividers, special cooling or additional hardware required.
Originally posted by: csflipfreakz
hey guys...am running it now with my corsair twinx1024-3200C2PT memory at 2.5-3-3-6 202mhz and 3x ht, 8.5x multi, 310fsb!! what do you guys think?? can i push it further?? or any suggestions on improving it??
Originally posted by: GRIdpOOL
the memory controller on-chip needs low latency and timings to achieve the bandwidth desired.
I highly suggest you, and anyone else interested in how the A64 interacts with your memory subsystem to read this.
i dont agree with zebos conclusion who used a lot of cpu intensive apps (raytracers, fft calculations, mp3 encoding etc.) to try to show the non importance of bandwidth.
A tool like Super PI or Prime or whatever does HARDLY utilize memory bandwidth.
Correct me if i am wrong.
And his list shows SOME gains in games and some apps where you can see quite some gains. It always depends on the app/game. He should use more game benches and maybe apps like video editing etc.
My opinion is a system should be balanced - means fast CPU, fast memory (and fast gfx 🙂. Everything will add up.
I'm not saying that LL RAM has no impact at all. I'm just saying that it has a very minimal impact. Basically, your money would be better spent on a faster stock CPU, or a better video card, ect...
You will see a higher return on your money spending it on hardware other then RAM. For example, you could buy a 74 GB Raptor with the money you saved on RAM. I can guarantee that you will see a much greater perceptible performance increase from a Raptor then from LL RAM.
Originally posted by: Zebo
Half-life 2 1024x768 in FPS
PC2300 - 3-3-3 1T- 113.3
PC3000 - 3-3-3 1T- 120.9
PC3000 - 2-2-2 1T- 131.6
PC4700 - 3-4-3 1T- 133.3
PC3800 - 2.5-2-2-1T - 134.4
Originally posted by: Dadofamunky
Of course, that didn't keep you from USING expensive RAM.... 🙂
I see a 10.7fps jump. I wouldn't call that minimal.
no the core speed is 2.635mhz from original 1.8mhz...memory is a little overclocked to 202mhz from original 200mhz....im jus trying to overclock as high as possible...also i dont get how memory is 202mhz...isnt 200mhz equivalent to ddr400?? bcuz when i boot with my oc settings, it says its on ddr266...shouldn't that be equal to 133mhz??
Never overclock again, infact:
Lock and ban.
My 386 ran at about 15 times the speed of that POS.
Had to do it. Someone had to.
It's definately not minimal, I think the point is that you can get 10.7 (or much more) frames per second if you spent the money elsewhere (eg the video card).
Its minimal if you consider that those 10.7fps just cost you about $200. Put that $200 towards the graphics card, and you will see a 10.7fps increase using the next highest res.
I origionally bought the RAM for a Barton @ 2.4GHz. If I was buying RAM spicifically for an A64, I'd get something a bit more modest though.
But I admit it, I usually buy the expensive hardware, just to see for myself what all comotion is about. 😛
