Originally posted by: NOLOVE
A very interesting read. Your side notes are effective and while the story isn't that engaging, you write well and have a very confident style (warm, not snide) that is nice to follow. Solid work, but the ending is a bit lacking?
Keep it up.
Did you actually read it or were you BSing? If you did read it and reached that conclusion, I'm amazed.
You're right, the story isn't that engaging ... well, not even at all engaging. The first few lines put me to sleep.
The author needs to ask himself who his audience is. It appears he's talking to a casual friend and informally. His use of some vocabularies doesn't seem convincing, therefore. It appears he just looked up the thesaurus. Grammatical errors ... too much cliches.... Cut down on the side notes in parenthesis; rather, incorporate some of them into your other sentences and eliminate the others. I think some are necessary parts of your story.
Maybe I'm too critical, but your work needs overhauling. It lacks in structure and transition. The paragraphs need more breaks. Things start to work at the point where you begin going out with your girlfriend, but then you return to the slipshod writing. The last paragraph, the ending, especially needs work. Also, this is supposed to be an autobiography, but I haven't even learned anything about this guy narrating the story. This story is just a chapter in an autobiography, but it's hard to appreciate it if you don't know who this is, and this chapter fails to reveal much about the author.
You have to give your reader a reason to go past the first sentence. You have to get your reader engaged. You have failed to do that, in my opinion. I could just be too critical, having done this almost as a....
