Who is having problems with their ati card? (just a show of hands)
Elvis2
2,710
Interesting thread. Looks like the vast majority of problems occured with non 9700/9700 Pro cards. I just bought a 9700 Pro (should be here in a couple of days) to replace my aging ti 4600. I wanted to be able to compare the two myself and decide which direction I was going to go with the next generation cards, R350 or NV35. Besides, I got a good deal on it and have a system I'm selling that would move a lot faster with either a Ti4600 or 9700 Pro installed.
HappyNic
641
I don't think this YES and NO will help you all that much, and it really is a flame war bate.
No problem , 8500
Sis 735
By the way I don't think a TV card is consider a videocard. They could have bad pictures just by what's hardware install in your system, your Cable line, your power supply, etc.. Did Nivida make a Tv card?
ivwshane
33,601
17,152
No problem , 8500
Sis 735
A tv tuner is not a video card but that's not the point of this thread. And a yes and no is helping me;)
Frodolives
2,190
I'm glad you're getting help from these user reports, and I won't presume to know exactly what you're going for, but in most instances you'd need to know the operating system being used as well to get meaningful data :)
Keysplayr
21,219
55
Yes. Unsolvable artifact problems in multiple systems. Radeon 9500 pro.
ASUS TUV4X PIII 1.2 GHz
512 MB mem
Problem Resolved. DX9 was required with cat 3.2 drivers. In that order.
sash1
Yes!
9700Pro/np and 9500Pro/np on numerous SiS 648 chipsets and on KT400 chipsets.
MangoX
623
166
NO
9500 Pro Retail
At7 max
had those problems with lines, but they're gone now since using the DVI output converter
optimistic
3,006
edit: I installed the SC4 patch, everything is running fine:)
No Radeon 9500 SIS645
SC4 was having issues, but was fixed with the patch.
Bovinicus
3,145
No problems here.
One thing to note: a lot of these people claiming problems doesn't tell you a whole lot. Some of those people are probably blaming the video card when it may not be the culprit. Just because problems only occur in games does not mean the video card is the problem right away. Games are far more intensive then office type applications. They can reveal problems that less intensive software cannot. Also, there may be a conflict caused by another component in the system. They also don't say whether they have upgraded to the latest drivers with all of their hardware.
Feel comfortable in buying ATi. Their drivers are really very good at this point in time.
EPoX 8KHA+ (KT266A)
Radeon 8500 (Retail)
Catalyst 3.2
blahblah
125
Don't have any driver problem with either ATI and Nvidia stuff. (I am running both)
8500DV with MSI KT3 Ultra
7500 With AMD 760
Before that was running, Rage 128, Radeon 32MB LE, Radeon VIVO all without any problems.
(also never had any problems with TNT, TNT2 Ultra, GF3 Ti200)
Initially I noticed signficant slow donw when I put in the 8500DV. Was getting 2000 in 3DSysmark 2001. After updating the Via 4 in 1 driver, the score went up to 7000+. (with latest VIA driver & Cat 3.1 I get about 8000, the card is clocked lower than regular 8500, I believe it's 230/230) And real game performance improved by quite a bit too.
Currently running Cat 3.1 with no problems.
gtd2000
2,731
Yes
Sapphire Radeon 8500LE 128MB
ECS K7S5A SiS 735 Chipset
No
ATI Radeon 9000 Pro 128MB
Same Radeon 8500LE 128LE works fine in other boards without issue - GF2's work fine in the ECS board also....:confused:
