tracerbullet
You're probably right. Been too long to remember. It was advertised as a 100 MHz chip though.
Pretty sure it was. IIRC they came in 25 and 33 MHz flavors. The DX2 66 was a 33 x 2, DX4 100 was a 25 x 4, etc.
The 486DX4-100 was a 25 Bus and a 4 Multiplier. There was also a DX4-120 but I think that was AMD only.
I don't remember what 486 branded parts AMD had, but their Am5x86 was a 486 at 133MHz. Reasonably fast for the price back then. It needed both a heatsink and a fan.
No, the DX4 was 33 FSB and x3 multiplier. The AMD 5x86 133 was a 4x multi. Intel had originally intended to make a chip with a x2.5 multiplier but it never came to fruition.
http://redhill.net.au/c/c-5.html
I had a Dell with a pentium 3. It just had a heatsink on the cpu. But it also had a case fan with a shroud that covered the heatsink. So would you say that cpu had passive or active cooling?
Convection can be "forced" by movement of a fluid by means other than buoyancy forces (for example, a water pump in an automobile engine). In some cases, natural buoyancy forces alone are entirely responsible for fluid motion when the fluid is heated, and this process is called "natural convection."
An example is the draft in a chimney or around any fire. In natural convection, an increase in temperature produces a reduction in density, which causes fluid motion due to pressures and forces when fluids of different densities are affected by gravity (or any g-force). For example, when water is heated on a stove, hot water from the bottom of the pan rises, displacing the colder denser liquid which falls. After heating has stopped, mixing and conduction from this natural convection eventually result in a nearly homogeneous density, and even temperature.
Via C3 750mhz.. naked
A bit off topic but it's kind of crazy to think back to my 486 and firing up warcraft2 and command and conquer. (c&c barely worked, had to run a special boot or whatever to free up the extra morsels of ram...I dont even remember the terms it's been so long!)
I've got an odd one as it is a Dell -- Pentium 4 2 GHz Northwood that utilizes a large heatsink and then has a plastic 'shroud' that funnels that to a fan thats about 4-5+ inches away at the back of the computer (like a typical case fan) -- no issues with overheating in the near 11 years of use. Tho I never did try and get a PresHOT(Prescott) as that would probably fry.
edit--looks like someone else noted this too, tho with a P3, mine's a P4!
I can remember look look on my cousins face when we had the heat sink off my P133 and turned it on, and he stuck his finger on it. I swear I could hear it sizzle when he did. Burnt him pretty good.
Yeah, it was "your cousin", yeah sure, that's how it went down, yeah :hmm:
