Which Refurb 21" Should I Get Out Of These?
Macro2
4,874
I hate to say it but it sounds like your luck of the draw wasn't good.
Will they replace it?
Macro2
4,874
Macro2
4,874
Metalloid
3,064
I have a P1110 and love it to death.
Flat tube, wonderful clairty, awesome brightness...
yhelothar
18,409
39
I think if it doesn't work, I'm just going to keep it using the manually adjusted settings..but anyone have an idea how to fix it though?
Macro2
4,874
if one color gun is weak you turn down the others or vica versa. It can be done internally if there isn't enoungh control externally. In your case there appears to be but things get worse over time. Eventually you will not be able to compensate enough.
Macro2
4,874
My biggest gripe with refurbs is that if you buy them from a long distance the shipping pretty much precludes returns and you get what you got.
I try to buy refurbs locally. Always look at the screen with a white background first...you can see the scratches if any.
I drove 3 1/2 hours for my G500, well worth saving $100 in shipping.
Finnkc
422
I have a NEC 22" and the funny thing is the NEC and DELLs are Sony Trinitron Tubes ... just you pay more for "Trinitron" name.
yhelothar
18,409
39
ok i think i found out the problem.. the green is out of focus.. when i turn down the green intensity, everything is sharp. damn i really don't want to RMA this... grrr
damn i should have gotten the IBM P260.. the price is now $285 for it
yhelothar
18,409
39
arrrggghh this monitor sucks.. the colors are all washed out looking... i just read the terms and conditions @ azatek.. they want me to pay return shipping!! grrrrrrrrr
yhelothar
18,409
39
pictures look great on this monitor.. but everything else the colors look washed out...
yhelothar
18,409
39
ok i just used color return a few times.. and i set the color temperature to 10300kelvin and now all the colors look nice...
but now the top and bottom is very blurry... grrr ...
