ClockHound
- Nov 27, 2007
- 1,111
- 219
- 106
I am going to prioritize RAM, at least so far as getting to 16GB's. Everything I've read seems to jive with what you're saying.
Do you think the 4690K would be a bad choice? If HT makes a significant difference I'll probably go 4790K. I just don't know how much difference it makes. I'm not too worried about big batches, just one project at a time, but would like to do panorama and multiple layers, etc...Trying to understand if we're just talking an extra couple seconds here and there or what exactly.
What do you think is the best way to arrange the storage? I am going to get one SSD, possibly two, but that's pushing it. I've seen recommendations to have a specific HD for everything, OS, program, scratch, working files and then storage...this seems excessive, possibly even excessive for a pro nowadays?
I can't seem to get any solid info on whether or not a separate drive for scratch matters much nowadays since you can just keep it on the main SSD. Not only that, but I still see people say put the scratch on a spinner even when they have an SSD? With 16GB's of RAM, I don't think I'll hit the scratch too much? Keep in mind I'm not a pro, I'd appreciate the performance, but I need to balance this as far as bang for the buck goes.
How much space does the scratch need?
I was thinking of just a 512GB SSD like you said. Then probably a 7200 spinner and then a backup drive the same size.
Does even the main HD need to be 7200Rpm's? I don't know if it makes much difference since I'm guessing I'd move the images I'm working on to the SSD?
If I were to get an extra SSD or even another spinner...what would I prioritize as it's use...scractch?...working file? I just don't know if saturating the I/O is even an issue at this point? What about for audio, if you happen to know much about that...I see people keep sample libraries on a separate disk. I thought if I got a second disk for scratch I'd put the samples there. I don't want to go that route though unless the benefits are significant.
If I can keep it to 3 drives for now and just add as necessary that would be great.
Thanks!
I haven't used a spindle disk for scratch in over 5 years...so my answer is...SSD.
Know one knows your workflow like you do. Or like you will. Why not just start with a 512GB SSD (MX100 is so cheap!) and a decent spindle drive. And the backup drive. Play with it and then decide.
SSDs are getting cheaper...so that's the one item you can always upgrade. If you wanted to be a little extravagant upfront, get a 256GB M.2 drive for the OS and a 512GB for working storage.
I would get a decent 7200rpm, WD Black or WD's Hitachi, but that's just me. Every second counts. Again, that's something you can upgrade at will. With a willing budget, of course. ;-)
