Which power supply for older system will be better?
imported_rk
124
need some help guys. just got a complete computer tower from a friend with no power supply.
here are the specs:
athlon xp - mobile 2400+ (45W) @ 185x12= 2.2 ghz @ 1.75v
2x 1gb kingston ddr 400
1x 512 kingston ddr 400
shuttle an35ultra mobo
1x dvd room
1x 160gb ide hard drive
x850xt platinum edition
everything else onboard
3 usb devices attatched.
My question is a dual +12v line power supply with lower amps work better:
http://www.newegg.com/Product/Produc...82E16817159043
or a single +12v line power supply with higher amps better? :
http://www.newegg.com/Product/Produc...82E16817709011
I know they're both junk power supply, but I dont want to invest in a system this old. Which would run this system better?
Jun 6, 2010
89
here are the specs:
1x dvd room
The ANTEC Basiq (BP500U-EC) 500W (by FSP) is a good option for you.
http://www.antec.com/Believe_it/product.php?id=MTIyMA==
In my opinion, you will have enough power in the +5V and +3,3V outputs with those 152W.
