PorscheMaD911
- Feb 7, 2005
- 128
- 0
- 71
Well, XP's been very stable for me. The only BSODs I've ever seen in were caused by a dodgey NVIDIA driver -- an update got rid of them all.
Originally posted by: Malak
2003. It's not just 2 computers, they were just examples. I have never seen a BSOD in XP. 2000 is an older OS, and therefore no reason to pick it over XP Home.
Originally posted by: BikeDude
What you're seeing is most likely more mature third-party drivers. MS have spent a lot of resources on their WHQL testing lab since 2000's release, and by eliminating the most common mistakes driver writers do, they've also immensely increased the perceived stability of the OS. But go back to 2000 SP4 using modern device drivers, and I think you'll find it every bit as stable as XP. I certainly measured up-time in months as a 2000 user back in the day. I dare say most people focus more on PSU and memory quality now adays as well.
_That_ said, Windows 2000 is not hyperthread aware. Its scheduler will see the HT virtual CPU as a real core and you run the risk of it scheduling real work to it inappropriately. At first I thought this was a problem with dual Xeon setups, but I've seen postings that indicate there are issues with regular single CPU P4 systems as well. YMMV, but it makes more sense to use the latest OS for the latest hardware. (OTOH we all use AMD, so this was just nitpicking)
Originally posted by: Seeruk
Yes Win2k is better than it was ...
Originally posted by: Brazen
Windows 98 SE
Originally posted by: Robor
but there are new games that require WinXP (don't run on 2000).
Originally posted by: Tarrant64
Kinda skimmed through second page but it has probably already been re-stated though. As far as I know W2k was far more stable than XP ever was. I mean, sure people can say XP is newer and blah blah blah, but IMHO 2k didn't have half the problems XP had(still has). Don't remember a single BSOD on 2k unless it was something I personally(user error) f'ed up.
I use XP now(pro) and it definetely just...crashes for no reason at times and there's a lot of software out there that when installed improperly(or it just doesn't like you and your hardware), it rips your pc to shreds.
Just my 2 cents.
Originally posted by: Canterwood
Each to their own, but please don't spout BS like that.Originally posted by: Malak
Windows 2k was unstable compared to XP, no reason to get something older and less capable.
Some people might actually believe you.
2K is perfectly stable and capable in games.
My friend got BSOD's in it quite often, I had it crash on me often, others had similar issues. I have never gotten a BSOD in XP, nor has my friend. XP is easily more stable than 2k. 2k won't be supported much longer, so there's no reason not to get XP. For gaming specifically, XP Home is the best OS to shoot for.
Lol. So lets get this straight.Originally posted by: Malak
If your XP is crashing for no reason, it's something wrong with your computer.
It seems to be just you repeating yourself over and over in the hope someone might believe you.Originally posted by: Malak
Anyone will tell you that. XP is the most stable OS Microsoft has ever put out, anyone will tell you that too.
Why, when you're making it such fun.Originally posted by: Malak
2k fanbois can exit thread now.
I wouldn't have been quite as harsh as that.Originally posted by: Malak
98 fanbois can die now.
Well ok, maybe I would if they'd said use WinMe! :Q
Win2K crashes on your PC, so its the OS thats unstable.
XP crashes on someone else's PC, so its their computer thats unstable.
Okaaayyyyyyy!
Originally posted by: PingSpike
I don't think XP is bad, its based on the mature 2K platform afterall. But it doesn't really offer much over 2K. Times may change and we'll see it fade away, microsoft is doing its best to speed the process...but right now, if you're on 2K, XP is a lateral upgrade, if that.
I guess you keep skipping over the posts where people mention the things that are not supported on 2k...
That doesn't make any sense, they are the same OS. The difference between XP Pro and XP Home are a couple features, the rest is the same. They have the same stability. In gaming, there is zero difference. Don't know what you mean by fresh boot, I leave mine running just fine.
not true, in terms of the interface, u r right that 2k is similar to xp, but in the background,
the kernel is quite different. win 2k was based on the NT kernel while XP is based on the
win 95/98/98se kernel. so there is a slight difference. anyhow, 2000 is more stable then xp but xp is better for gaming as it is better supported.
:thumbsup:
Regardless, SLI is the only one I've seen brought up.
XP supports all the new security fixes in SP2. This includes a more functional firewall, built in pop-up blocker, info bar, etc. There is no equal for this in W2K.
Firstly, the firewall. Key word is more functional, as in less suckage. No equal for that in W2K, so I consult my nearest tech guy (me) and install the free Kerios 2.15 firewall. Its more functional than Windows built in firewall (ie: less suckage)and it filters outgoing as well.
Nextly, the built in pop up blocker for W2K would be Firefox, but since that hasn't been out forever, I would then use PopupStopper 2.6, another freebie that doesn't even have a splash/nag screen.
Lastly, the extensions to Firefox make it so much more advanced than IE that it isn't even a fair discussion. Several free utilities cover any necessary or even eye candy appeal for a given OS, with Microsoft choosing to not provide OS security patches to make the OS safer to use. Thats obviously by design. Now I am not arguing the outcome ... please don't feel that is my contention, I simply feel that an OS discussion is just not going to please all of the users all of the time. You cannot force a Ford guy to love Chevys and vice versa. Given my situation even three months ago, I would chose W2K, but I know I cannot hold onto it like Linus does his blanket, I do have to move on and update ... only because I had no choice.
Fixed.Originally posted by: Malak
Win2K has NOTHING on XP. NOTHING! [Maniacal laughter] Ahahahahahahaha Ahahahahahaha
