Which Lian Li for me???
EndGame
1,276
OK, decided to go ahead and order one...........need to know though, I've found the regular V1000, the V1000 Plus and the V1000 Plus II............are the plus/plus II worth the extra money? I can't even tell for sure what the difference is!:roll:
Operandi
Have you taken a look at the V1100? Due to it's closed front bezel and solid AL door it will be quieter then the V1000. Its also better looking in my opinion.
EndGame
1,276
Yeah, I've looked at it but really, don't want to spend much more than the V1000 costs right now...............just want one to see what the Lian Li's are like...........still want to know if the plain jane V1000 is good or should one go for the Plus/PlusII model? Still unclear as to the differences..........
EndGame
1,276
OK, still don't know exactly what the differences are between the plain V1000, Plus & PlusII, but now have another question.................I'm wondering if my Tuniq Tower will even fit inside the V1000 depth wise...........
LOUISSSSS
8,771
58
yes it will fit. even my scythe ninja with 120mm fan attached fits with clearance. i'd get the plain. the plus version that comes with the vga blower fan is pretty loud so i removed it after the first week. and it exhausts air anyways.. it wouldn't provide any benefit for my gpu hs/f
essasin
2,777
I believe the plus comes with an intake and some other accessories. I do remember there was a recent revision to the lian li's and plus II could be the revision.
secretanchitman
9,353
23
i have a PC-75. only get it if you want the room. seriously, theres nothing else. get the 7B or whatever its called.
or how about the anniversary edition that looks like a 6?!?!?! lol...
EndGame
1,276
LOL! Yeah....I think I need the room..........Still not sure the Tuniq Tower will fit.....
Tuniq Tower
Plus I want something easy and roomy to work in and cools well........
