its too bad, I am tired of the false BS advertising involving that shit on TV's. the day they make a real 120hz TV, we can get affordable decent 120hz gaming panels
Had the BenQ for a couple of days and hated the image quality. We have cheaper TN's at work that look better.
Exchanged for the ASUS VH236HE and never looked back - fantastic picture quality, even next to my 30" VA.
Did you tweak the settings for your benq? I hear that the monitor is quite good, but only after you've changed all the out-of-box settings.
On another note, the only standard i have to go by is my benq g2400 24" monitor. I know the 120hz monitors will be very fluid as far as gaming goes, but for those of you who have used the same monitor i have, do you know how it will compare to the selection of 120hz monitors currently available? Or rather, since i am pleased with how well my g2400 has performed, which of the 120hz monitors are at its level, if not higher, as far as response time and image quality, etc.
thanks!
Is the Acer HN274H not out yet?
my BenQ XL2410T came out of the box with the "FPS" mode as the default, this is a mode specifically designed to provide a competitive edge while gaming and thus will look terrible on the desktop or for watching movies. Heck, it will look terrible for gaming, but again, its made that way to provide a competitive advantage as BenQ went to great lengths to tweak this monitor to provide significant (and even arguably unfair) advantages for gamers when it comes to seeing in darker environments whether you're using the 'FPS' or 'User Game-1' or 'User Game-2' display modes. Some look a lot worse than others but also make it much easier to see in dark environments.
That being said, 'sRGB' mode provides quality that is just about on par with any other TN panel LCD, and the 'Standard' mode allows tweaking to make the monitor above average. Although either mode will be darker than average while gaming.
At the end of the day this monitor is not for those who want an all around monitor, this is most definitely a monitor that is first and foremost going to provide the user significant advantages when playing fast paced games, particularly competitive first person shooters.
I want a GLOSSY H-IPS W/ EXTERNAL POWER SUPPLY, RGB LED, AND 120Hz INPUT WITH <=12.5MS INPUT LAG AND A CALIBRATED CONTRAST RATIO OF >=1050:1.
Sucks that it will never exist.
Are there any H-IPS or PVA/MVA 8+ bit panels on the horizon that will do 120hz? Not interested in downgrading colour quality to TN to get 120hz.
What I would absolutely love however, is for better controllers. I understand the panels won't be able to really keep up much past 150hz, but there is no reason why we can't have that thing outputting line-by-line (CRT style) at 200hz+. The ghosting would only be visible in extremely niche situations such as a light being toggled on and off at the resonance frequency of the monitor
I went with the LG w2363d. Based on the various review sites, it seemed to have the best image quality, least overdrive artifacts, thru-mode, and good price. My only complaint is that the menu buttons are hard to use, but once you set it up you don't have to mess with them. I was considering the Benq for its LED backlighting but at the time its initial reviews indicated it had bad backlight bleeding (which may have been fixed in later production).
Can you give any details? I've been considering the SA2311W, but can't find many reviews for it.<3 my planar 120hz
The BenQ may have the lowest input lag, but several reviews mention that it has slow pixel response compared to other 120Hz monitors.
this is only potentially relevant to those who are looking to avoid artifacts while running 3D, but even then the BenQ more than meets the standard for achieving 120Hz (ie sub 8.333 ms pixel response)
at the end of the day there isn't an LCD that is better when it comes to sheer 2D performance for fast paced games
I have 3 acers and run 3dvs and love all 3 of them they work great and look greatHi everyone,
I'm in the process of building my new rig, and I'm pretty certain I want to go with a 120hz monitor. The ones i've been following are the asus vg236, benq xl2410t, acer gd245, and alienware aw2310. Of these, which is the best for cs:source, mw2, blackops, mw3 when its out, and starcraft 2?
I am somewhat concerned about price, but if the monitor is well worth the money, I'd rather pay up for something really good.
I've heard good reviews and bad reviews for all these monitors, but what do you all think? Are there any other monitors i should consider? Thanks for any and all help!
Thanks, dkcode for the response.
It had better be good because I just ordered itI posted a short review in the last 120hz thread if you want to read it. http://forums.anandtech.com/showthread.php?p=31249954&highlight=#post31249954
There's no way I'd willingly game at 60hz again =P
Also Planar is based in Oregon I believe and you get free rma shipping and actual English speakers if you have any support issues, if this matters to you.
Where did you get the LG? It doesn't look like it is made anymore. I can only find refurbs.
