Which headunit should i go with?
EightySix Four
5,122
52
Originally posted by: NutBucket
Not a whole lot of difference unless you're going for an audiophile-level system.
You think an Infinity Kappa Perfect System is considered Audiophile badge worthy?
NutBucket
27,162
638
Heck no!
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
What does it do, just output at a louder, cleaner volume?
NutBucket
27,162
638
Makes the signals less sensitive to noise.
If you have a 1 volt signal and .5V of noise....you're definitely going to hear it. If you have a 5 volt signal and .5V of noise then you're not going to hear it. Unless your car has a horrible electrical system it won't matter.
bigrash
17,648
28
that widescreen is nice, but not where it's located. i can't image watching videos (and that's the whole point to widescreen) on that little screen all the way in the front of the car. it's not like you're watching video on a psp that's closer to you.
i'd go with the pioneer out of those two
jtvang125
5,399
51
I'm debating swapping my Kenwood for the premier, does anyone know how much a diff going from the 2.5v pre-outs to the 5v would make. The amps max out at 5.5 volt.
Trying to find that out myself as well.
I had an Eclipse before with 5v preouts which I sold and got an Alpine with only 2v preouts. I thought there was going to be a difference I can hear but nope. To me the Alpine actually sounds better than the Eclipse. This was using quality speakers and a external amplifier.
NutBucket
27,162
638
Heh. You're the first person I know of that prefers Alpine SQ to Eclipse. To each his own:)
Accipiter22
Banned
Feb 11, 2005
7,942
I LOVE pioneer....I have a dehp9300 from a few years back..wouldn't trade for any other head unit on the market
Svnla
17,986
1,388
I have Alpine for a few years and I like it. I also heard good things about Pioneer.
Don't let me start with JVC. I will never buy that brand until I die. My JVC TV died on me after a year <little useage and the screen just went dead>.
aphex
Moderator
Jul 19, 2001
38,572
JVC's past history does scare me a bit...
Im pretty sure im gonna end up with the Premier, i like the rotary dials, makes it much easier to browse mp3's and sirius stations.
Aharami
21,205
165
Originally posted by: theNEOone
ugh. why people would mess with a perfectly good interior is beyond me. the mazda3 interior is one of the nicest in its class.
you should adjust your prices because putting in an aftermarket headunit is going to be at the expense of a dash that looks like sh!t. plus you're going to lose the time display AND the use of the stereo/volume controls on the steering wheel.
Time display will be on the new radio.
They make adapters that splice into the wiring of the wheel, allows the streering wheel controls to work with aftermarket systems. The SWIX is one off the top of my head. Also, higher end eclipse's can wire directly in without any aftermarket adapters.
just installed this in my gf's tC along with the SWI-ALP for her steering wheel controls. Works perfectly and i think SQ is better than my Pioneer DEP-8600MP. Also hooked up her ipod via this. With this cable, you control the ipod via the HU but since her steering wheel controls work with the SWI-ALP, she can change tracks and FF/RW on her ipod via her steering wheel controls. Just make sure you read the directions carefully BEFORE hooking up the SWI-ALP
aphex
Moderator
Jul 19, 2001
38,572
I think ive decided on the Premier after reading the following reply on another forum
the pioneer actually has an independant L/R 16 band eq (ie a seperate 16 band for each side), not to mention time alignment. The auto eq will get you a roughly flat frequency response as well as set the T/A for you (that's the best part). The crossovers can go all the way up to -36db/oct for the sub output and -24db/oct for the front and rear which is MUCH higher than normally possible. (most radios and amps have -12db/oc xover slopes).
Another cool thing it does is allow you to try an active system if you want. In an active system, the passive crossover between the woofer and tweeter is not used, and the speakers are instead crossed over inside the head unit or processor. The advantage of this is that you can easily adjust the level of the tweeter and woofer independantly of each other, as well as time align them independantly (instead of just picking a spot roughly between the two). The crossover point between the two can also be played with at much higher slopes than in a normal passive crossover and all this can be done while sitting in the driver's seat. Plus takign out the passives gets rid of the power robbing coils and capacitors. The disadvantage to all this? You need seperate amplifier channels to both your tweeter and woofer. This means either a 4channel amp withthe fronts to the tweets and the rears to the mids, OR two 2 channel amps. This is why I have so many amps in the sytem I'm building - it is a fully active 4 way system (tweeter, midrange, midbass, subwoofer)
Here is a link to some more great info on active systems http://www.bcae1.com/elxovsp2.htm
Higher voltage outputs allow you to reduce the gain on your amps, while still getting them to reach their full output. The advantage of this is a greatly lowered noise floor, and better sound quality in general.
scorp00
994
Get the pioneer. I've had a pioneer premier 600 series for 4 years now. It's a great head unit.
randomlinh
linh.wordpress.com
i'd so go w/ the pioneer... that looks so damn nice.
with that said... it's hard to match anything in our cars... the blasted red accenting looks cool, but makes it hard to go aftermarket.
aphex
Moderator
Jul 19, 2001
38,572
yea, im trying to find the best of both worlds... good sq yet still a nice looking interior
aphex
Moderator
Jul 19, 2001
38,572
Originally posted by: Howard
By iPod compatibility you just mean that it has an auxiliary input, right?
no, all of them have full ipod control...
text on screen, browse by artist/song/title/etc.... charges ipod while connected... etc...
NutBucket
27,162
638
Just one question. How is the OEM nav going to interface to the new HU? Do they all play together?
EDIT: You should just consider a higher quality LOC; namely, JL Audio's Cleansweep.
aphex
Moderator
Jul 19, 2001
38,572
I thought about it, but its not just the better SQ im going for, its the full integration....
And the OEM nav has its own joystick/controls right next to the shifter... The voice will continue to work as well as it has its own seperate inline amp that ties in later down the line... (cuts sound to front left speaker and plays voice)
