Going by your workflow, you can buy whatever card you think is a good value and your experience in CS6 will be about the same.
Ok then now I guess i'll think about gaming. Will a 650 ti provide decent fps on most games?
I found a used gtx 580. Would that be good?
It has some mods, but idk if they are really bad. It says
1. The card has unlocked bios. 1.212V max on the Vbios (is this really low or something? does it matter?)
2. The heatspreader on the card has been removed, but still on the card because of the stock heatsink. Aka, Removing the nvidia heat spreader guide. (i assume this isnt very bad, right?)
3. The card has a little cut out of the top of the cover for the Antec 620 mod. (this one i dont care about much)
1. That's high. You can restore it back to normal, assuming nothing is wrong with the card.
2. Makes no sense to me. How is it removed but still on there?
3. Cover is plastic.. makes no difference.
If the price is good enough, the GTX580 is faster the GTX660. Could be a good buy.
Maybe he means he has removed it before but put it back? idk. But if its going to be better than a gtx 660, then I think i'll get it. Will my system (power supply) be able to run it? It'd also be pretty cool to say I have the top of the line gpu, the 580 (because that matters so much, i know), lol.
As long as you restore that voltage to normal and don't overclock it much... you should be good. The 580 is very power hungry (244W TDP compared to GTX 660's 140W TDP), but even combined with the CPU's TDP you're still under the max limit of the PSU. I wouldn't go for anything more power hungry than a GTX 580 though.
82C is hot but still fine, but you're at the edge. You'll want to clean out your case to make sure you get good airflow, maybe add a few fans if you can.
Yes, but once again... I would advise against it. The Zotac GTX 660, which is $195 right now after rebates, will be quieter, newer, less power hungry and will have a warranty. The last part itself is worth tons... if there is something wrong with the card, you get a new one. It's only a bit slower (within maybe 10%) than the GTX580 and you get more benefits.
You know what, I might just get a used 560 or 560 ti. I found a 560 for $100 flat, a 560 ti for $125. Any other opinions? You really think I should go with the 660?
