Question Which CPU would be best for gaming?
jamesdsimone
1,007
286
Undervolt the 6800 XT is one option or limit the fps to 60.
I guess the PSU is having trouble handling that.
I think server PSUs are designed to be overprotective and wouldn't allow such high instantaneous power peaks.
Wonder if there is any settings in BIOS that might help.
jamesdsimone
1,007
286
Did you check the Windows Event Log? Powering off automatically could be due to the CPU reaching dangerous temperature so it shut itself down to prevent further damage. An anomalous power surge could also trip the PSU's protection circuitry.
What log do I look at?
Markfw
May 16, 2002
27,406
16,256
BTW, just a recommendation. In the future do not buy anything Dell, especially proprietary computers. This is a common result.
My recommendation would be to buy a whole new PC, and start with something like a Zen 3 or Zen 4.
Reactions: winr
19,219
System in Event Viewer.
Event Tracing for Windows (ETW) providers are displayed in the "Applications and Services Log" tree. Logging for individual components can be view, enabled/disabled - and are a great place to start troubleshooting a component.
^^^ never tried that but it could be useful.
19,219
I looked under power events and there is nothing but entries concerning the system going to sleep. The hardware log is empty. Any other type of log I should look at?
So it's probably a sudden hard shutdown, not allowing Windows time to record an entry.
You could try using two different 8-pin connectors, attached to different cables instead of on the same cable from the PSU.
Reactions: jamesdsimone
jamesdsimone
1,007
286
This is mostly just a project I decided to work on. It's a Lenovo P520. There are a lot of videos about using the P520 as a base for a gaming computer but the fastest graphics card I have seen used is an RX5700XT. I already had the RX6800XT so used that. I usually stay away from proprietary hardware.
Reactions: DAPUNISHER
jamesdsimone
1,007
286
I think I have some spare 8 pin cables. I'll try swapping cables. I can try downgrading the video card but that would suck.
DAPUNISHER
32,448
33,454
Don't forget to use InSpectre to turn off mitigations James. It can range from no real loss of performance to quite significant depending on the game, with those older Xeons and i7s.
jamesdsimone
1,007
286
Be careful with that. Unless it's a generic cable, some cables are proprietary and using them with some other brand PSU could cause electrical problems.
I have two single 8 pin ribbon cables. It is from one of my other PS but not sure exactly which one.
jamesdsimone
1,007
286
Ended up pulling the CPU cooler and reapplying thermal paste. After that temps dropped 1-3C.
During a transcode boast clock speeds hit 4.3Ghz which they didn't before. The heat sink is pretty light so I'd like to replace it but I need something that doesn't need the back plate changed otherwise I'd have to tear down the whole system because of course the side panel is riveted not screwed. When I was rooting around in the case seems one of the 8 pin connectors was loose so I'm an idiot. Can't believe I didn't notice it before. I ran Deus Ex benchmark about 12 times and no power offs. No change in frame rate though after reapplying thermal paste. So no you can't run an RX6800XT with one 8 pin power connector. I'll have to stress it with some gaming to be sure.
