Been really happy with my 6950 -- had it ~ 2 mos now and it has performed flawlessly. Is my first AMD card in 6+ years.
Better tesselation performance with heavier tesselation loads.
(which no games make use of atm, mainly shows in tess heavy benchmarks)
PhysX.. how many games support GPU only PhysX? on the pc? ~20 games?
CUDA is dieing... Directx's alternative DirectCompute, and OpenCL are replaceing it, withtime less and less CUDA only software will be around.
The tesselation reason though is a valid enough arguement for the 560 though, I guess the PhysX is too, if your playing one of those 20 or so games.
I still think 6950 unlocking to a 6970, means its value is better.
Power wise, it uses 20+ watts less on avg loads.
performance wise: 6950 > 560:
560 is closer to a 6870 than it is to the 6950.
560 is ~5% avg faster than a 6870.
6950 is ~8% avg. faster than a 560.
Arkadrel, would you mind please posting a link to where you're getting those bar graphs from?
pretty sure that is TechPowerUp.com
Thanks!
Yah mean like this one?
http://www.techpowerup.com/reviews/MSI/HD_6950_Twin_Frozr_III/23.html
Basically says it all.
The lower your resolution, the better it is to get NV.
1024x768 to 1680x1050, NV is the way to go.
1920x1200 or above, AMD is faster.
It says a lot more than that.
Anyway, to the OP. Go for the 560Ti.
too many TWIMTBP titles
Battleforge,Call of Juarez, Civilization, skewer the results to much.
So let me get this right -
A TWIMTBP title shouldn't be benchmarked unless it favors AMD hardware, is that what you're saying? There are a large number of TWIMTBP games that run faster on AMD hardware.
This nonsense has to stop.
Starcraft will run well on pretty much any midrange GPU or greater. It's a CPU hog, though, and it prefers Intel processors.
