You can get the DW-U12A (which is the OEM version on the DRU-510A)
here for $271 shipped
No the DW-U12A is the OEM version of DRU-500AX and hence it won't support 4x DVD+RW and 16x CD-RW.
DW-U14A is the OEM version of DRU-510A.
Check out the
link and say that again.
Sure I can because:
DW-U10A=OEM DRU-500A
DW-U12A=OEM DRU-500AX
DW-U14A=OEM DRU-510A
The links go to Buffalo Japan that sells the OEM versions. The site is in Japanese but check the reference to the model numbers and compare the specifications with Sony's retail versions. You can also check
the firmware page if you need more "proof".
Please, step away from the keyboard. You have NO idea what you are talking about! Did you even click on the link I gave you? It clearly states the DW-U12A is the DRU-510A. After I posted a link in ENGLISH, you post a link in Japanese?
The DRU-500A and DRU-500AX are basically the same drive! The only difference is a firmware update. Once you update the DRU-500A, it performs just like a DRU-500AX. The DRU-500AX is just the DRU-500A with the updated firmware. The DW-U10A
IS the OEM version of the DRU500A/AX. The DWU-12A
IS the OEM version of the DRU-510A. DO you REALLY want me to give you a list of links showing the above. And it ain't gonna be in Japanese!
And that firmware link you gave me, I wouldn't trust them with those hacked firmwares as they have their facts mixed up. Check out what it says about the DW-U12A, OEM version of the DRU-500A. I thought you said it was the OEM version of the DRU-500AX?
