Which antivirus do you use?
kmmatney
4,363
AntiVir (www.avira.com)- Its really been a great program with low overhead. I like it so much I tried to pay for it, but they did not have the United States as a listed country in the Billing window and don't seem to support sales to the U.S. However its still a great program.
Dec 12, 2004
29
I had Norton Anti-virus 2006 for like a day or two and got rid of it even though i didnt think it was that bad. Maybe slowed the computer a little but thats about it. Decided to give BitDefender 9 a shot. Have no issues with it, does whats its meant to, updates itself, has constant file scaning, also has a firewall but i dont use it because im using the Windows XP firewall SP2. The only thing is when you do a full system scan it takes a while. Also BitDefender was ranked no.1 AV on some site, cant remember where though. Oh plus its way cheaper than Norton AV 2006!!!
imported_goku
7,613
Originally posted by: deagz
I just tried Symantec Antivirus 2006 but it is too bloated. It installs a dozen services and uses 50mb of ram when it is CLOSED. Took me half an hour to disable all the services and remove all the startup programs, and now the program will not start manually. I will uninstall it because I find it simply ridiculous that a simple antivirus will permanantly use up system resources like that.
Does anybody know of any good antivirus programs that do not devour system resources?
Just get kaspersky. Don't question it, just get it..
imported_goku
7,613
Originally posted by: ajikan
Symantec Norton Antivirus... it came with a 3 month trial so I guess I'll use it for now.. :)
You'd be better off with a trial version of kaspersky, norton has horrible detection rates..
Rottie
4,795
I use NAV 2006 on my desktop (no major issues) and AntiVir on my laptop.
TheRyuu
5,479
14
Originally posted by: Soviet
So Antivir > AVG?
Wasent the case last time i checked, everyone loved AVG. What happened?
Antivir has better dection rate than AVG and the best between all the free Anti-Virus's.
And I use Antivir7
