Which 2GB 6950 would you recommend?
happy medium
14,387
480
Could you expand on this? In other words how does the GPU speed limit the amount of vram usage?
Sure.
Example:
Take a game like BF3.
A 6950 2gb at ultra settings will use 1.3gb of memory yes, but a 6950 2gb will be running at a non playable 27 fps.
A 6950 2gb running some high and some ultra settings will use 990mb of memory at a playable 40 fps.
But if you add the horsepower of another 6950 you can run the game the ultra settings , using 1.4gb of memory at a playable 40+ fps.
Simply a 5870, 6950, 6870, gtx560ti 384 core gpu does not have the power to give proper framerates when using setting that use more than 1gb of memory.
You need 2 cards to have payable framerates if the settings are turned up to use more than 1gb of memory.
happy medium
14,387
480
Wait till tomorrow and look at the gtx560 ti 448 core benchmarks if your paying that much for a 6950.
Unless you gonna crossfire or sli 2gb of memory means nothing, 1.25gb is plenty.
I think new cards will be out before you even consider crossfireing or sli.
