<< how do you plan to install it then? A/C doesn't generate cold, it merely moves heat outside of the dwelling. >>
There are units that you can cart around. They have a tube that you stick outside to vent the hot air out. They are usually more expensive than the comparable window units though.
I think another alternative would be a water based cooler. These might not work as well, but do cart around and use less electricity.
Well, yes, I do need to install a venting part of a portable unit in the window. I guess I could hide it somehow from the freaking manager, but not the whole window AC unit...
<< There are units that you can cart around. They have a tube that you stick outside to vent the hot air out. They are usually more expensive than the comparable window units though. >>
really? That's the first time I've heard of them. Learn something new everyday, hehe If you want to go budget, you can always just buy a block of dry ice every morning and stick it in the living room, hahaha
