Where to get HCl solution?
MadScientist
2,183
63
wait, so you're extracting this into HCl to lower the dose? Why not just chop up the pill? I'd be extremely hesitant to acidify a tablet and then try to use the drug, and I'm a chemist.
I'm a chemist too and I agree. And what about the inactive ingredients in the pill: colloidal silicon dioxide, corn starch, lactose, magnesium stearate, microcrystalline cellulose, and povidone, will they all dissolve in HCl???
As twinrider1 suggested, get yourself a small mortar and pestle, grind the pill up, divide it up into 10 equal portions as best as you can, or buy a small scale and weigh them. http://www.amazon.com/s/ref=nb_sb_noss?url=node%3D16439881&field-keywords=mortar+and+pestle&rh=n%3A16439881%2Ck%3Amortar+and+pestle
sjwaste
8,757
12
I didn't realize antifungal medications were now code words for making meth.
Seriously though, I wouldn't try this at home. If you have to, using a mortar and pestle to pulverize it, then using a scale to divide (by weight) seems like your best option.
Have you called a pharmacy to find out if smaller tabs are available?
zinfamous
111,866
31,364
98% would be a gas. 37% is pretty standard, as more than that and it fumes quite a bit at room temp.
You're probably thinking sulphuric, where 98% is a pretty standard strength.
what do i look like, a chemist?
But you're probably right. I don't have much use for either on a daily basis. but I do have HCL, H2SO4, glacial acetic, etc. All reagent grade.
The only one I use regularly is propionic.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
What about grinding it up into a fine powder, then blending it with something harmless (corn starch was the first thing that came to mind, since it already might be present), and hope that with enough mixing, it forms a homogenous mixture. Then, dividing it into 10 equal sized doses might be a bit easier.
Slew Foot
12,379
"pretend" like youre making pot brownies. Just smash it up real fine, distribute it into a large mixture, divide into even pieces.
Matthiasa
5,755
23
As mentioned several times just go to a local pharmacy and have them do something for it.
Unless you feel like poisoning yourself then go right ahead with your current plans.
Slew Foot
12,379
Sudafed is made of pseudophedrine hcl. You should go to all the pharmacies in the area and buy up all the Sudafed. Then all you have to do is separate the pseudophedrine from the hcl.
Dec 10, 2005
28,897
14,171
Maybe buy some cleaning products at the same time and just jump straight to the crystal meth....
Slammy1
2,112
I rather doubt Sigma will sell to anyone (anti-terrorist and drug laws), and even if they did I would not recommend using reagent grade acid to make a pharmaceutical preparation (unless you know what you're doing).
I used to use MS grade acids, 99.9999% pure.
