Where should me 3dmark2001SE scores be? And what's yours?
kami
I get about 9640
AthlonXP 1800+ o/c'ed to 1628MHz
Soltek SL-75DRV4
512MB Samsung PC2100
MSI GF4 Ti4200 128MB o/c'ed to 300/550
Blargh
77
right now 10900 ..... but i didnt oc my vid card yet
1.8a @ 2.4ghz
512mb pc800 @pc830
Gainward golden sample gf4 ti 4400 (stock speed)
Insidious
7,649
Yet in a very intense graphics game like Nascar Racing 4, both ran about the same 38fps with high details, D3D.
Tried another basic 32bit 3d game, Links 2001, and both performed and looked about the same.
Have seen the same thing here. (no significant fps gain when comparing GF3 and GF4 4400) I was dissappointed at first, but
after a little poking around (articles and the like....) I found that NR4 is one of the most CPU intensive games out right now. To
satisfy myself, I messed around with processor speeds and did see a corresponding fps change in the game.... This led me to believe
that NR4 is CPU limited on my setup.... not Video limited as I would have guessed.
HOWEVER, I did notice that I could up the antialiasing with the 4400 and get significant gains in picture quality without any significant
fps loss (still talking about NR4 here). So there is a gain with the 4400 over the GF3.
(yeah, I know none of this is groundbreaking news.... just thought it was interesting)
bcterps
2,795
I got in the 6800s.
GF4Ti4200 (315/540) 29.42 drivers
P3-850@952 112mhz FSB
Win XP
I'm pretty satisfied with my score, I know its my CPU/FSB that is really holding me back. My card would run at 315/560 rock solid, but there were too many visual artifacts during 3dmark2001se for me to be satisfied with it. I'm hesitant to try to up my fsb to 124, but I'll probably give it a go later tonight to see if it will run stable.
--Ben
Mavrick007
3,198
So it seems 3dm2k1se is designed to give higher marks for specific features manufacturers incorporate for the sole
I agree as well Rob, but you have to compare "systems" like yours to see how they compare to really get the benefit out of 3dmarks.
If another system that has very similar components as yours is getting 1000 more 3dmarks than you, then there's something that he's doing with his settings that you're not and maybe you could be playing the new great game better without upgrading.
Here's a question for people on a new system build.
My friend just made an AMD 1800+, with MSI GF4 Ti4400, with 512Megs PC2700 Samsung ram on an Asus A7S333 (sis 745 chipset).
He's getting 7100 3dmarks on 3dMark2001 SE with everything at stock speed. I thought it was low and that he should be getting around 8500-9000. Could it be some setting in the video or the chipset on the mobo or what? I was wondering what would be holding him back.
drewdogg808
1,513
make sure the bios settings are on optimal/highest and see if he can run his memory at faster timings (cas 2, etc...) i've found that tweaking the bios and memory can really increase system performance and 3d mark!
cmdrdredd
27,052
357
P4 2.63ghz
512Mb Samsung PC2700
Abit BD7II mbo 155Mhz FSB
GF4 Ti4600
WinXP
SupermanCK
2,264
P4 1.6A@2.4GHz
512MB PC2700 @ DDR400
ASUS P4B266-C
Visiontek Ti4400 o/c to 300/650
Check my sig for more info
Zeeliv
1,213
11111 :D
System and 3D Mark linked below. I was only a few hundred away from 11K so I put my FSB up until it went over. I'm sure I could go farther, I just don't feel the need...yet. :)
Frazas
124
You can check the specs in the sig in more detail, but in short terms is a Athlon XP @ 1875, Radeon 8500 300/300, 512mb Kingmax DDR333, Epox 8K3A.
deadcell
51
Dammit, i need to get 3dmark.......but anything over 10mb is a bother to dl. stupid ass 56k.
tokamak
1,072
Athlon XP 1800+ (not overclocked)
512mb pc2100
Radeon 8500LE 64mb
radeon @ 250/275 (default): 7877 3dmarks
radeon @ 275/300: 8187 3dmarks
overall, i'm satisfied, although my scores do seem a bit low....
Actaeon
8,657
20
6694 3d Marks
Though, its full of artifacts (only in 3d mark), it runs very stable.
Not so bad for a 1219mhz Athlon, Ti200, with 512mb SDR.
AMD Athlon T-Bird 1.13@1219 (8.5x143)
Ti200 @ 240/544 with 29.42 drivers
Generic 512MB SDR
Abit KT7A v1.3
Windows XP
Here is 6232.
Runs stable, no artifacts with all the eye candy turned on.
Same rig as above, but Ti200 @ 200/544
You choose which you want to compare.
I'd say not so bad, I could use a faster CPU though.
Jman13
811
3DMark2001SE - 8130
AthlonXP 1700+@1800+ (1540)
512 DDR
GF3ti200 @ 230/520 (for benchmarking, keep at 220/500)
Jman
