Originally posted by: Duwelon
Are the anandtech reviewers even working on reviewing the P45 chipset based motherboard(s)?
I don't know whether or not to say that's interesting, or disturbing. Did Intel add some sort of clock limiter on the P43? 400FSB absolutely sucks. P965, P35, G31, etc., can do far more than that. I thought that the P45 was on a new process (a shrink), and thus should be able to overclock more. Anything less than 500FSB for a dual-core is sub-standard.Originally posted by: Gary Key
We will cover the P43 also as it is basically the P45 with overclocking limited to 400~415FSB.
Originally posted by: VirtualLarry
I don't know whether or not to say that's interesting, or disturbing. Did Intel add some sort of clock limiter on the P43? 400FSB absolutely sucks.Originally posted by: Gary Key
Not necessarily, seeing as how many of the current 45nm cores have high multipliers. E7200 has 9.5x, right? E8400 is 9x and E8500 is 9.5x. At 400MHz FSB all of these will hit 3.6GHz, which is really respectable. Only the E8200 won't hit limits (but it isn't priced to great).
Perhaps you consider it respectable, but if E8400 and E7200 can reach 4Ghz on the core, then I consider a 400Mhz FSB limit to be wholly underperforming.
Originally posted by: ssiu
This Chinese website overclocks an E8600 ES to 530Mhz FSB on an ASRock P43 motherboard:
HKEPC Hardware
It was only testing "Super PI" and not something like Prime95 ... but the gist is that there doesn't seem to be any artificial FSB limits on P43.
HKEPC Hardware
I have the same motherboard here, doing 425 stable with a BIOS that will be released to the public. I saw 500FSB on an engineering board when visiting with ASRock, but they insisted those results were not representative of retail boards. I do not doubt for a moment that the P43 will do 475~500 stable with a good MCH, but they were insistent (as were others) that the P43 would be regulated around the 400FSB level for the most part. If that changes, then we all win.![]()
I have 13 boards in for testing at the moment. The GF8200/780G comes first in a week, probably be around 7/11~7/14 for the P45 roundup. We will cover the P43 also as it is basically the P45 with overclocking limited to 400~415FSB. The majority of the boards will be in the $125~$175 range.
