Where do y'all HT guys buy speaker wire from? People buying from Home Depot, please read!
tronester
27
You dont need more than 18awg speaker wire. Unless you are running extremely long lengths, or 1-2ohm speakers. Very doubtfull. Any wire you can find will work. Dont be fooled by thinking that spending more on wire will make for better sound, it simply wont, and scientific tests have been done proving there is no difference, provided the wire is thick enough for the current demands.
Think about it. You probably have 24awg wire in the voice coil of the speaker, run for SEVERAL feet. Do you think 10feet of a substantially thicker 18awg cable will make any difference?
http://users.htdconnect.com/~djcarlst/abx_wire.htm
Pheran
5,740
35
I use 14 gauge speaker wire from Home Depot in my setup, it works well. DO NOT use Cat5 cable, despite what some people have suggested. It's typically 24 gauge and is not designed for high-power signals. You might even risk starting a fire attaching Cat5 to an amplifier.
GasX
29,033
anyone who tells you that monster cable is better than Home Depot lampwire is either a delusional marketers wet dream or is comparing 2GA monster cable to 20 GA lampwire.
Go to Home Depot and find the spooled wire section then buy the largest gauge wire you can stand. 12 GA is pretty much what you want.
GasX
29,033
addendum: if you aren't a crazy elitist audiophile, you can stand smaller wires - which are far less offensive to the eye and easier to hide.
NuclearFusi0n
7,028
If you do it right, it kicks ass. The wire isn't just a single strand of 24 gauge, it's about ~100 strands used together.
read the link
http://www.venhaus1.com/diycatfivecables.html
fatbaby
Banned
May 7, 2001
6,427
i recently checked the bgmicro(.com) catalog...they were selling monster cable (audio) for $20 per a 100 ft. roll
Pheran
5,740
35
OK sure, if you take a bunch of 24 ga strands it should work, but frankly it's not going to sound better than decent 14 or 12 gauge speaker wire, so I fail to see the point of all that effort.
Garion
2,331
7
read the link
There are two kinds of Cat5 cabling - Stranded cable that's designed to be used for patch cables and cables which are frequently moved. Solid core Cat5 is designed to be used between patch panels and jacks. Most big spools you buy, unless you specifically get stranded, are solid core.
- G
Bulldog7000
292
Just get some of these and you will be happy... guaranteed(unless spending buttloads of money on speaker wire makes you sick)
There is just something about cables that are rated based on percent of speed of light... :D
Nordost Valhalla
BDOG
LikeLinus
11,518
670
This coming from the same guy that thinks Sony's low end A/V receivers are "good" lol.
Please go spew this BS you spread over at Hometheaterspot or hometheaterforums and see what they say. :)
tronester1
29
I post on hometheaterforum.com in the DIY section often. I do not post in the other sections. There is no reason to bring this up in that forum, it has been dragged on constantly. If you want to believe your expensive cable will make a difference, GO YOU. I however, have more important things to spend my money on. If you like, bring it up in the DIY section, I will be sure to respond.
Before you call my statement BS, why dont YOU explain to me why it is? Mr. cable expert, why should I spend 100 dollars a pair on speaker cable? Why infact should I use wire larger in diameter than 18awg when utilizing a 10 foot run with 8ohm speakers? I personally use 16awg, Just because it looks better than the cheaper 18awg, I could hear no difference between it and the 16awg.
Also, why don't you give me some reasons why Sony recievers are bad? Lack of features? Lack of power output? Don't try and convince me there is a difference in the amplifier "sound quality". An amplifier is simply a voltage multiplier. If two amplifiers sound different, then one is designed to introduce a phase shift, excessive THD, or boosts or cuts at certain frequencies. Or of course you could have such a poor ampliifier that it is actually audible - I have never heard of that happening.
I await your response, O king of sound.
