where did my micro sd card go?
LTC8K6
28,520
1,576
I lost the microSD card for my Nook. I was trying to put it in the slot, and it was just gone. Couldn't find it anywhere. Looked for an hour. Mystified me.
Turns out it went inside the case between the card slot and the case.
Opened up that corner of the case, and there it was.
wirednuts
7,121
4
its still lost. i cant believe it. i just had everything the way i wanted with that card... i hardly care about the money its just, ugh... i know its in this room and yet i feel like theres a real chance ill never see it again
wirednuts
7,121
4
FOUND IT!
sorting through laundry for wash, it was on the floor between the clothes and the basket. it is over 10 whole feet away. that sucker really flew!
rh71
52,844
1,049
it is probably between the clothes and the basket on the floor over 10 feet away.
13,810
They should put metal on these things, at least you could use a magnet to try finding it. lol
One of the fastest ways to find something is to go buy another. When you get home, you'll find the old one.
CZroe
24,195
857
Hey, wirednuts. Perhaps you can tell me: Will an HTC Sensation boot with no battery while plugged in? My friend's phone may be broken but it could just be that the battery wont charge. I already replaced the screen once about a year ago but this seems different because I can't always get it to boot with the EL lit soft keys lighting up.
shortylickens
80,287
17,081
that is one of the reasons i hate micro SD. i have a bunch of them and have lost 2-3 of them this year.
I have a Rubbermaid drawer right next to the computer and theres a special little place for all my flash memory, USB or not.
waggy
68,143
10
i have on too. with 5 drawers. i keep pens in one, pencils, eyeglass stuff, junk and then memory (flash, usb etc)
wohoo!
wirednuts
7,121
4
if your soft keys light up but no screen i think youre in trouble.
my sensation doesnt do jack shit plugged in without the battery in it. no lights, no nothing. mind you, i dont know if it matters but mine is S-off, rooted, jb rom, and CID unlocked
CZroe
24,195
857
Thanks. Yeah, it sounds like it may be a problem charging.
Last year before I replaced the screen it was at least booting. You could tell because it would buzz and then the soft keys would light up a bit later. Now I have to play with it forever while messing with the charge port to get the buzz and even then the soft keys never come on. I think it is dead and unable to charge. Playing with the plug enough to get it to momentarily charge/come on, it still can't make it to the point where the soft keys light up without going dead. I did get them to come on once but they stayed on so I think I locked the phone up or something when playing with it and was probably ruining the battery.
