Originally posted by: zaku
is 8 gauge sufficient for a groung wires? or should i go 4 gauge? will be for scion tc.
It depends on what you are trying to ground really. What exactly are you using it for? Car stereo install?
i want to make a "hyper ground" kit myself. like 4-6 wires grounding different parts in the engine bay.
Originally posted by: So
copper bus tubing is the only viable route.
also, what the hell do you use to crimp a terminal onto a 4 gauge wire? my wire crimper is only good for smaller gauges.
Originally posted by: AmdEmAll
Go HERE
This guy can custom make them to fit your car.
I have it on my Impreza, made quite a big difference.
Go HERE
That guys price on wire is about the same as the other two places, and he doesn;t even give any specs on it...
Besides, half the fun is doing it yourself...
i wouldn't rule them out so fast until i tried it out for myself. the tc doesn't have a throttle cable and is all electronic. other tc owners in scionlife reported better response after adding additional grounding wires.
