- Dec 27, 2001
- 3,506
- 95
- 91
yes. plaster. what headache? i will pop a 9x9inches access panel in, wont patch it up with compound 45minsPlaster? You might be opening yourself up to a real headache.
Oh wow a flat roof for a house. That's not too common. That whole setup looks more like what is typical of a commercial building, even got a packaged HVAC unit going on. But yes there may still be a small attic in there, that circle is a vent. Going to guess you got metal trusses in there like you see in the ceiling of places like Walmart and they just made it into an attic, almost wondering if this is a converted commercial building. Blown insulation could be tricky to do in this case as there probably is not a lot of room to work with.
row house. half of the house is attached. the other half, back of house, is not attached. so there's a mini alley between neighbors, about 4 feet wide. all bricks, so the walls are very cold too because there is no insulation between the brick and the plastic wall. this is why i am very tempted to do vinyl siding to squeeze polyiso sheets between the vinyl siding and the brickIs that a row house / townhouse? Attached to the neighbors house on each side? Not much you can do there. Doesn't look like there is enough room for any meaningful insulation.
Mayby try window film if they are leaky.
You're talking about a major job by professional contractors. Many thousands of dollars.row house. half of the house is attached. the other half, back of house, is not attached. so there's a mini alley between neighbors, about 4 feet wide. all bricks, so the walls are very cold too because there is no insulation between the brick and the plastic wall. this is why i am very tempted to do vinyl siding to squeeze polyiso sheets between the vinyl siding and the brick
Why? Vinyl siding is really quite easy to do, especially if you don't have to cut around a ton of penetrations. He could throw some foam boards up with some construction adhesive, put some furring strips in to give something for the vinyl to attach to, and then slap up the vinyl. Probably still several thousand dollars depending on the square footage (insulation isn't cheap).You're talking about a major job by professional contractors. Many thousands of dollars.
It's not easy to attach to brick, 3 stories up. And for what, an R value of 4? Definitely not worth it.Why? Vinyl siding is really quite easy to do, especially if you don't have to cut around a ton of penetrations. He could throw some foam boards up with some construction adhesive, put some furring strips in to give something for the vinyl to attach to, and then slap up the vinyl. Probably still several thousand dollars depending on the square footage (insulation isn't cheap).
