Where can I cut costs? (Mid Range)
lehtv
11,897
74
You can save another 10 bucks if you go with an Antec One at amazon.
Unfortunately, according to specs, Antec One can't fit Hyper 212+
http://i.imgur.com/KyrQW.png (212+ newegg)
http://i.imgur.com/KWuXq.png (Antec One hwsecrets)
And who really needs a dvd drive anymore?
People who have physical copies of games or software, or collections of DVD movies, etc. Not uncommon. OS installation still also typically requires a DVD drive, most people aren't willing to go through the trouble of making a USB bootable Windows.
mfenn
22,400
www.mfenn.com
IMHO any tech savvy person should have a dedicated 8GB USB drive with the Windows 7 installer on it. It's super convenient and a hell of a lot faster than installing from the DVD.
lehtv
11,897
74
I haven't bothered to do that yet, lol... Maybe I'm not tech savvy :\ ... :D
sm625
8,172
137
You're spending $200 on a case and psu for a system that will pull 70 watts idle and under 200 while gaming?
Try an antec 300 case and earthwatts EA-380D psu for under $100 combined. That saves you $100. You can probably nix the 3570K in favor of the cheapest i5-3XXX. Your motherboard will let you overclock to the highest turbo bin with one move of a slider. Unless you're buying a cooler you cant go much higher anyway so K is kind of pointless. TIM conspiracy has made sure of that. If you are delidding, then by all means get the K. Also consider a 2500k if the price is right. You are very likely to get more than 10% more overclock on a 2500k compared to what you can get on the 3xxx. Unless there is some reason you need the newer uA?
