Originally posted by: Excelsior
How was it not valid? I still went and found the price of the 36GB and posted that, and it is more expensive. I wasnt trying to say that "oH MAN that thing is SO EXPENSIVE even though it is a 73GB drive".
Its not ironic, because you couldn't believe it costs more. Just like now, you are basically trying to say the Raptor isn't cheaper in the long run. Yes the Raptor is more expensive, but is it CHEAPER than the SCSI drives it performs comparably to? YES, if you can't see that then I feel sorry for you. It sounds like to me that you just can't believe a SATA drive is doing this well, and still you haven't used one. If you or mechBgon actually bought one, tried it out, then I would fully understand everything you had to say, but now,its just bashing.
Yes, WD didn't live up to their promise of 30% less, but it does equal the drives it is $10-20 cheaper than and does do better in some cases. And you could always say the price may fall drastically in the next few months. Not to mention it is quieter and cooler than those drives. And you are somewhat wrong,
if those prices are for DELUXE versions of motherboards that cost a lot more, then ok.
Granted. some deluxe version with SATA are much more expensive, but they do have a lot more than just SATA. A SCSI card won't give you anything else. And as motherboards progress SATA is moving down to the "less expensive" versions. It is widely know that SATA is a standard, and will replace PATA. Is SCSI gonna replace PATA? No. And the same could be said about SCSI, the majority of the people dont have it. Id bet that more people have SATA and don't use it than those that have SCSI and do. SO why not give those people a reason to use their SATA. I still say for $168, and all they have to do is plug it in, that the Raptor is a good deal. And I still say that SCSI is superior, but more expensive.
Im more open to each side, SATA, and SCSI. However, it seems as though SATA wins in the cheaper but good performing HD for the masses that have SATA. And as more people upgrade, more and more end up with SATA. The same can't be said for SCSI.
