When will 4 gb of memory be recommended for PC games?
Pollock
1,989
Right now.
When you can get 2x1GB for $20 AR if you look carefully, why not get 4GB? Even if you're using a 32-bit OS, you may as well max out your usable amount right now, with how cheap RAM is.
treetops
7
If you plan to play games like age of conan with vista 64 bit you might need it now, the minimum requirement specs for aoc are 1gig for 32 bit and 2 gig for 64 bit right? So I would not be surprised if you used 4gig with 64 bit vista on age of conan.
pcslookout
11,964
158
Whoa. I need to check out the specs for age of conan didn't even realize a game required a minimum of 2 GB of ram now, at least on Vista that is.
KMFJD
33,346
53,305
So far AoC has peaked at 1.8gb's of memory usage with 64 bit Vista with max setting
pcslookout
11,964
158
Wow seems to be helpful to have 4 GB to have some breathing room.
