When is HyperThreading NOT beneficial to the user?
waffleironhead
7,113
614
The primegrid llr app does not do well with ht. From my experience you more than double the time each item completes. You either need to disable ht or tell boinc to only run on half the available cores.
coercitiv
7,450
17,766
I fixed the slowdown in minimizing / restoring my windows, by telling BOINC to only run one two cores (threads) instead of three.
Out of curiosity, could you try another setting as well? Four threads instead of two, but lower max cpu utilization a bit.
VirtualLarry
56,587
10,225
Well, I've largely switched over from PrimeGrid to NumberFields on that box now, but I tried setting it to use 100% of processors (all four threads), and 90% CPU usage.
Now, it doesn't actually hold the CPU usage at 90%, it kind of modulates it, and I see it skipping between 1%, 30%, 60%, and 100% fairly regularly.
Regardless, my window minimization doesn't seem to be affected any more.
Edit: I guess I ran out of GPU compute WUs too.
