When do you think we'll see transparent aluminum products at the consumer level?
JEDI
29,391
2,738
Star Trek is reality:
waiting for Transparent soda cans :D
MrPickins
767
It's not really aluminum, though. It's a ceramic that is something like 30% Al.
zerocool84
36,041
472
Depends what you consider consumer level. On cars, that type of stuff would only be on super cars that none of us regular people could afford.
destrekor
28,799
359
Depends which type it is: is it ALON, or heat-pressed spinel? Spinel, or MgAl2O4, is about 37% Al by mass.
But ALON (or AlON when not using the trademarked variant), Aluminum Oxynitride... well I can't find the specs.
Both are ultimately taking advantage of a similar method, creating a ceramic composed of a spinel crystal formation. I believe the heat-pressed variety is taking straight MgAl2O4 as a powder and heat-pressing it... but AlON is more of a generic description that can describe a few different molecular compositions.
CZroe
24,195
857
Pics in the OP are wishful thinking. Aluminum isn't being used to eliminate seams in other car body panels so why would transparent aluminum that replaces the windshield be used for that? It's a bad thing anyway. Most people think individually replaceable parts make more sense. Those people are right. Also, you can't smash the window to get out if the aluminum bends.
The reasons we don't use plastic to make that same concept car today are the same reasons we wouldn't use aluminum even if it were transparent (it scratches, it bends/isn't rigid, it doesn't shatter where you might need it to, etc). They aren't thinking this through.
Greenman
21,751
6,176
Isn't "heat pressed" sintering?
MrPickins
767
That's what I was getting at, though. You can't call this aluminum any more than you can call a ruby or a sapphire aluminum.
It's not aluminum and it doesn't have the properties of aluminum.
sandorski
70,655
6,222
Any day now. It was estimated to take 20 years to understand the matrix(IIRC), but computers have improved a lot since then and there are always complications along the way that muck about with estimates. At any rate, there have been plenty of delays already.
CZroe
24,195
857
...and if it had the properties of glass or plastic we'd be using those. The fantasy is in what properties of aluminum we can retain in a transparent form.
The OP did not say what kind of transparent aluminum the pictures were depicting... a fantasy one or the one you are talking about. There is no link so I don't know why you're so sure he isn't talking about Star Trek transparent aluminum.
destrekor
28,799
359
I imagine all of that COULD be done... but would it be practical? For the car? Nope to the nope.
But for the kayak? Hell yes please. That would be awesome.
MrPickins
767
Really I'm just venting because all the headlines I see in articles about Aluminium oxynitride describe this as a transparent form of aluminum, and people take it at face value.
CZroe
24,195
857
Why can't you do that with plastic? Is there any reason to think that aluminum would be better or more scratch-resistant or more able to flex?
What I'm saying is that there is no sense in imagining things that are already perfectly possible with other materials that do not require any special properties of transparent aluminum.
destrekor
28,799
359
Because. :colbert:
Rakehellion
12,181
35
You mean sapphire? Apple tried to do that with the last iPhone but their partner wasn't able to keep up with demand.
khon
1,318
124
Sapphire glass has been used in consumer products for years, and that's transparent aluminum by your definition.
werepossum
29,873
463
Given that aluminum oxynitride is more dense than water it would only be awesome once, until submerged. Then it would be drifting along the bottom and damned hard to find.
CZroe
24,195
857
Metal ships float when most any shipbuilding metal is more dense than water. The entire volume of the submerged portion must be less dense, which is easy in a boat-shaped design that displaces most of that volume with air. You can make a glass boat too! :colbert:
