Black88GTA
Originally posted by: Nutdotnet
If you have a Costco membership you should really check them out. Last time I was there they had a great and sturdy-looking aluminum low-profile jack. Was very lightweight.
Arcan ALJ3T, at Costco for $160 or so. I picked this one up a couple months ago, because it had all the specs I was looking for. 3 ton capacity, very low min saddle height (as ZV said, IMPORTANT), high lift, and aluminum construction (I think it's about 60 lbs). The saddle is very large with a rubber pad, if you were concerned about that. It looks like a very high quality tool, and seems very sturdy. I've only used it a couple times since I got it, but haven't had any problems. I was also considering the HF aluminum one, but I like being able to return it to Costco without problems if it does go bad.
My only complaint is that it raises slowly compared to my old jack, but that's not a huge deal to me. I had to replace my old steel jack because since lowering the Trans Am and the Prelude, it no longer fits underneath.
Edit: Link
