What's your view of FF 3.0?
SaltBoy
8,975
11
Originally posted by: sirjonk
anyone use Safari? my quicktime tried to autoupdate but i squashed it.
It's nothing special and doesn't add anything unique to the browser game IMO. If you like the iTunes interface, which I have no problem with personally, you might like Safari.
Muadib
18,120
910
The plugin installer is not working for me. It just searches endlessly. This is with Vista x64. It worked fine on my xp rig.
Kelvrick
18,422
I want the [x] button on the right side of hte tab bar back. When the tabs resize themselves, I can't quickly close multiple ones because the [x]'s move.
Locut0s
22,205
43
Yeah but I've gotten used to that long ago since they changed it back in 2.x something. You can right click on a tab and choose close all other tabs. Usually when I want to close tabs I want to close all of them or only 2 or 3 so it's not a HUGE inconvenience.
BCYL
7,803
I have been running it for over a week now, never had it crash on me, and it's noticeably faster than FF2 so I'm loving it!
Kirby64
1,485
Used it for awhile, then it decided to crash and refuse to start. Had to go back to 2.0. Not a big fan of the 'dynamic history' or whatever. More of an annoyance than a benefit.
Shawn
32,236
53
Originally posted by: Safeway
Do most existing extensions work with the new Firefox?
they do if you modify their install file
I'll look that up.
Originally posted by: rubix
it's easy to make any extension work with any version of firefox:
download extension (.xpi) to your harddrive. open .xpi file in winrar. drag install.rdf file from inside .xpi to a temp location on your harrdrive. open .rdf file in notepad. find the min and max version part and edit to make the max version 4.0 or whatever. save changed .rdf file. drag .rdf file back to winrar's open .xpi file to update it. drag updated .xpi file onto firefox. it'll install the extension and work now.
it takes like 8 seconds once you get used to it.
Feb 19, 2001
20,155
23
i like. using it right now. It definitely is a lot faster in loading pages. The app itself? Faster? Ehh.. The new address bar is slick though.
Duddy
4,677
14
I never liked any of the Final Fantasy games. Whether it be FF 3 or FF 7. RPG's aren't for me.
Locut0s
22,205
43
Did that just go ten miles over your head or are you attempting a sarcastic post in reponse to dennilfloss' Final Fantasy joke?
