What's wrong with my car?
Maybe one of the brake pads is loose and rubbing against the rotor. When you brake it pushes the pad back in to place and stops the noise temporarily. Same when you make your right turn, the force of turning pulls the pad away from the rotor. I don't know a whole lot about cars, just a thought that came to mind.
That's actually precisely what I suspected was happening, but given my ignorance of cars I didn't trust said diagnosis.
I do not know much about cars, but do you have enough decals? Is the wing big enough...and on straight. What about the carbon-fiber hood? Check that stuff out first.
My car is covered in decals, you can't even see the windows! My NOS system takes up most of the back seat, which limits my interactions with the ladieezzzz.
My wing is bigger than yo mama, and it's definitely on straight.
w3rd
If you're going to Ricer-Troll, at least wait for a thread that's not about a minivan. 😛
- M4H
- M4H
My minivan can SO roll with the best of them.
- M4H
Quit trippin', h8tr.
- M4H
- M4H
- M4H
hozer
"...it doesn't specify whether the sound occurs while braking or while not braking..."
Can you make a wine glass sing by rubbing your moistened finger around the rim? Notice what happens when you press harder? Same thing with the wear sensor when you brake. It's still rubbing, but not able to "sing".
:\ Point.
It's a crude little 'L' shaped piece of spring steel, attached to the pad. It would normally squeal when the brakes are applied, as it touches the rim of the rotor, but yours may be past that point.
Metal to metal would produce noise when you pressed on the brakes. If what he says is accurate, it is not the brakes. Tale ?tale tabs on brakes are not what he is explaining either. They would make the noise when ever you first hit the brakes
- M4H
It was exactly the minivan thread that I was looking for! RICED MINIVAN BABY!
