Originally posted by: vshah
Originally posted by: LeetViet
Originally posted by: mitchafi
I'm using a CRT but 1280 x 1204 seems to "fit" better than 1280 x 960
What he said.
the same
Originally posted by: acemcmac
I use 3x 1280x1024 :beer:
crt's in rig specs
Originally posted by: bykim5
My LCD is at 1280 x 1024, every other reso is blurry.. 2 1/2 years old.
Originally posted by: halik
Originally posted by: FrogDog
Holy FVCK stop posting like that.Originally posted by: Xiety
---------- Xiety says -----------
I actually heard that 1280x960 is better than 1280x1024? Can anyone confirm this? If yes, why?
---------- Cheers----------
2nd
EDIT:
hehe i read the other comments, more like 6th than 2nd
What he said.
the same
Put up a picture of a perfect circle. You will see it does not "fit" better, but is, in fact, distorted. Everything is slightly short and squat on a CRT at 1280x1024. The proper resolution is 1280x960.
Just because you're used to that short and squat look doesn't make it correct.
Try this image, and measure it both vertically and horizontally. On my monitor it is an exact circle. On your's, it will be longer than it is tall.
http://mathforum.org/~sarah/shapiro/gsp.percent.circle.gif
What he said.
the same
I measured that circle and came up with an oval at 1280 x 1024 (which is what I normally use). Then I switched to 1280 x 960 and came up with an oval (plus the screen had huge left and right "margins"). So I adjusted my monitor settings to make the screen take up the whole tube, and measured the circle again and it really was a circle. Thanks!
What he said.
the same
You are welcome. Now go and spread the word, my son.![]()
What he said.
the same
I don't see it... I must be retarded![]()
First off, what kind and make of monitor do you have?
Samsung 955DF-T/T.... Three of them side by side
OK, do you stretch the picture using the monitor controls to fit the edges on the monitor exactly in both the 1280x1024 and 1280x960 resolutions?
it's such a pain to do all of those adjustments, that once I got it at 1280x1024, I left it on all three.
Originally posted by: Koing
Perfect circle on my 23" lcd @ 1920x1200.
I use to ru n 1280x1024 on my 19" CRT as it was the largest res my eyes could take.
Koing
Originally posted by: Syringer
All the other ones, like 640x480, 800x600 and 1024x768 is a 4x3 ratio, 1280x1024 is 5x4. Why? It should be 1280x960.
Koing
Wow.
I used to go to LAN parties and was amazed at some of the resolutions some people were running. So high you could barely make out the text - you had to squint to read it. I believe it was mostly people just showing off their monitors.
I run 1280x960 on my 22" CRT and that's as high as I will go. 1600x1200 is out of the question.
