zerocool84
- Nov 11, 2004
- 36,041
- 472
- 126
Originally posted by: Corn
Originally posted by: BassBomb
A decent quality 18" wheel is usually lighter than the stock 16" ( at least for my car )
16x6.5 stock
18x7.5 is what i was looking at
This, and usually high performance tires which come with the larger wheels also tend to be significantly lighter as well.
And as has been pointed out, a quality 16" wheel will be lighter than a quality 18" wheel, while performance tires for a 16" wheel will be lighter than performance tires for an 18" wheel.
All else being equal, the 16" variation will be lighter.
Additionally, even if the 18" version were the same weight, it is still worse because it has more weight farther from the wheel's center which increases the rotational inertia and hurts acceleration and braking. The only performance reason to use larger wheels is to fit larger brakes.
ZV
Just curious what percentage of stock OEM 16" wheels you would consider to be quality and/or more lightweight than the larger factory rim options? This thread is about OEM offerings, right?
I think it'd be impossible to know with all the different OEM wheel offerings out there.
I know with the version of my car that I got, it came with BBS's that are smaller/lighter and wider than the ones that come with the regular version of the car.
 Facebook
Facebook Twitter
Twitter
