What's the highest revving normal production car?
Flyermax2k3
3,204
Originally posted by: NFS4
RX8:
Max Horsepower: 8500 rpm
S2000:
Max Horsepower: 7800 rpm
WHOA! the RX8 produces 8500rpm of horsepower! That's amazing!!!!!111one ;)
I'm not sure what your peak power comparison is trying to prove... The OP simply asked which production car has the highest redline, not which car makes the most power at the highest rpm.
But why would you want to rev it past max power?:confused:
You'd have to look at the power curves in *each gear* to determine what your shift point should be at. Just because max power comes before redline doesn't mean you should shift @ that point.
ndee
12,680
RX8:
S2000:
Depends on the power curve, no?
Apex
6,511
www.gotapex.com
RX8:
S2000:
To maximize acceleration? :)
You want to shift at the RPM where the HP in the lower gear will equal the HP in the higher gear. This point is always above max power.
NFS4
48
RX8:
S2000:
I was thinking more along the lines of keeping the RPM at that level for a sustained period of time. Not during upshift which is normal. I'm quite sure that there are plenty of cars that can do brief spurts at higher RPM levels, but I was thinking more along the lines of revving it past max for a sustained period of time.
NutBucket
27,180
649
RX8:
S2000:
Oh. That's pointless, unless you're racing and need to acclerate soon.
johnjbruin
4,401
I thought ferrari's were up there too. But none of you have mentioned it so i might be wrong.
Flyermax2k3
3,204
Ferraris don't exactly qualify as "normal" or "production" cars ;)
NutBucket
27,180
649
Maybe not for you:p;)
Demon-Xanth
20,551
Originally posted by: notfred
Originally posted by: Demon-Xanth
Yamaha R1: peak HP: 188HP@13,750 RPM.
Bike != car
I know, but it puts things into perspective when people tout how high the 1.6L VTEC revs when there's a little 1.1L engine that goes much much higher. Though I'm happy w/ my 6k redline. :D
boyRacer
18,569
Bike != car
Those liter bikes only need to haul 400-500lbs though.
