Originally posted by: jagec
Originally posted by: lokiju
Originally posted by: binister
Originally posted by: Mwilding
Painter's tape works great, just pull it off within an hour of painting.
This being the case, how does it apply to doing a primer coat?
Say I want to prime first (which I do want to do) then that has to dry for at least an hour before I can apply paint. Do I apply paint after that dries and then pull off in an hour or does pulling in a hour after applying tape only apply if there is no primer in the picture?
If you're painting the walls and ceiling, you don't have to put tape on at first, since you'll be putting primer on everything. It's once you have to paint different colors (like a white ceiling and blue walls...for example) that you need to tape it off.
If you're painting along a trim piece, it's easiest just to remove it and paint past the edge, then replace it for a perfect finish.
