What's the difference between Format(Quick) and Format
inveterate
1,504
I know Format (Quick) is quick, but what's the real difference, and are there advantages to using either?? TIA
OffTopic1
1,764
Quick Format -- Clear files name from the table.
Format (regular) -- Does what Quick Format do, but take more time because it also run CHKDSK to check & mark bad sector.
Muse
40,436
9,945
Yeah, so if you do a quick format you are taking the chance of not having the current bad sectors marked and potentially losing your data. I normally don't do a quick format unless I've done a full format very recently.
