What's the difference between an LCD TV versus an LCD projection TV?
Fritzo
41,920
2,161
LCD shows picture directly on screen.
LCD projector uses light to project an image onto a screen.
Kind of obvious? :confused:
MrDudeMan
15,069
94
Text
basically the picture from an LCD screen bounces off of a mirror and through a lense of some sort that magnifies it onto the wall. a regular LCD just shows you the picture on an actual wafer of semiconductors - but its basically what they use inside of a projector, just smaller since there is no magnification.
Phokus
22,994
779
Originally posted by: Amol
Originally posted by: Phokus
Ok so regular LCD is better than LCD projection?
Each has their advantages and drawbacks.
Like? I've been trying to find a site that discusses pros and cons of each but i can't find any :(
olds
50,125
780
I have been looking at and will get one or the other. It depends on the screen size you want. Projection doesn't look as nice as just LCD.
But, I want the Hitachi Ultravision 70" and it's projection. If you sit too close (+-6' or less), they suffer from screen door effect (SDE). You can see squares in the picture
