What's the big deal about Dual Overhead Cams?
Mill
28,558
Originally posted by: OuterSquare
My car has a DOHC motor. Midrange and low end is just fine, I can leave tire marks from a dead stop even though it's just a 4 banger econobox. :Q
i'm calling BS on this one.
ehh, whatever. Doesn't matter to me if you believe me or not.
What kind of car?
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
I could do that in my prelude by tossing it into drive from 5000 rpm. fun till I toasted the trans.
OS
15,581
Neutral drop? Man even I'm not insane enough to do that. :p
Demon-Xanth
20,551
Damn near everyone beats V6 Mustangs. The Ford 3.8 V6 and GM 3.4V6 made for some slow ass "muscle cars"
LAUST
8,957
Dropping the clutch??
Powerbrake.
He's not BS'n then... The Video is a power brake also... Front turn back sit
I should have someone get my truck on camera when I go by at 40Mph and floor it and break em lose :D (OHV) ;)
Evadman
Feb 18, 2001
30,990
I don't have OHC. I have OHV. Close as I can get. I have a I head Lawnmower :)
lRageATMl
327
Originally posted by: Yucky
New stangs (don't deserve capitalization) aren't worthy of speed.
I beg to differ...step into my car (or Millenium he has a sweet ride too) and I'll give you a whole new perspective.
B00ne
2,168
dont worry dual overhead cams are old - soon car engines will loose the cam altogether. Like F1 engines already did. Technology usually is first explored in Hightech R&D extensive Motorsport and then migrates (when economically feasable) to the mainstream market....
Kadarin
44,296
16
OHV (non-overhead cam) design does not automatically mean your redline is limited to 6500rpm. (My '83 Mustang made power to about 7200rpm.) You do, however, need to pay attention to what parts you put in the motor: Roller cam and aluminum (needle-bearing, not ball/socket) roller rockers to reduce friction; camshaft with specs to make power at the desired rpm range, and valve springs with the right tension to make sure the valves do not float at that rpm. Appropriate intake manifolding and exhaust flow, along with cylinder head optimization to make sure there's enough airflow to feed the motor. Good rods, rod bolts, harmonic balancer, and other infrastructure. Synthetic oil.
B00ne
2,168
So basically, some day car manufacturers found out, if we want to meet our goals, instaed of doing all of the above it is cheaper to simply use 4 valves per cylinder and DOHCs (and probably produces a smoother running engine too by avoiding all that mass moving around at very high rpm)
