When you first initially feel the symtoms, go ahead and take a bunch of comtrex. You still will have the cold, but I often find it isnt as bad or strong.
Juicing usually does it if you have a juicer. If you have a strong stomache then it's no problem but if your stomache are real weak it'll make you throw-up.
