whats the best water filtration system that you get for your home?
JEDIYoda
33,986
3,321
I am in the market for either a water filtration system for drinking water or putting a high tech culligan system in the house.
Any suggestions?
BoomerD
66,525
14,907
Is your tap water really that bad?
Mine is. Our tap water is "iron rich" and heavily chlorinated.
Previous owners of the house had a double filtration system installed. 2 "Big Blue" canisters with sediment and carbon filters. The sediment filter is always orange from the iron/rust when it's removed. I've kicked around the idea of putting in a proper water filtration/softener system...but at over $4k, if it gets that bad, fuck it...we'll move...again.
sdifox
100,868
18,078
get your water tested then you know what kind of iron filter you need. Sizing would of course impact price, but for two people don't go hog. Water softening is not really good for you if you are on low sodium diet. you are replacing calcium with sodium.
BoomerD
66,525
14,907
Previous owners of the house had the testing done. According to the filtration people who service the system, I have the right filter cartridges... (I'm a virgin, I've never been lied to before) :rolleyes:
I understand (on a limited basis) what water softeners do...and the cation/anion exchange media is SUPPOSED to remove the excess sodium. (IMO, the price for the system is too high. ($4k-$6K plus annual maintenance) We're not biting.
sdifox
100,868
18,078
Test the water that the system puts out :awe:
Micrornd
1,386
243
As sdifox said - test the water!
Use a qualified lab, not some water service or test strips, but a real lab.
When you have the results post and ask -> https://terrylove.com/forums/index.php?forums/water-softener-forum-questions-and-answers.22/
You shouldn't have a problem being under $1k total and under $100 a year for expendables if it is only as bad as you say.
Remember, the removal of iron (and other bad things) is a separate process from water softening (if done properly).
BoomerD
66,525
14,907
I had forgotten about this thread. This is last year's filter change:
Reactions: killster1
killster1
Banned
Mar 15, 2007
6,205
475
I'd say a reverse osmosis system like this: https://www.homedepot.com/p/APEC-Wa...rinking-Water-Filter-System-RO-PH90/206343435
They have a few "cheaper" models by the same brand there, but the filtration isn't as good as this model, and you did use the term "best".
that is close to what i would recommend, except the ones i use have a UV light (no idea if it helps). I use two of these one to fill 5 gallon jugs, and another built in under the sink for a backup when the 5 gallon needs to be changed.
34,709
The UV works if the pre-filter is installed and maintained correctly. If particles big enough to shade the germs make it through the filter, the effectiveness of the UV drops.
bbhaag
7,477
3,091
Dang how the hell do you get away with yearly filter changes? I have a similar setup installed at my house and I'm lucky to get 2 months out of the filters.
BoomerD
66,525
14,907
At $100 per change, that would suck. They PROBABLY should be changed more frequently...maybe every 6 months, but I'm cheap...unfortunately, those filters, as good as they are, do NOTHING for reducing the high TDS in out water. It ranges from around 300 to close to 500 ppm.
NutBucket
27,162
638
Yep, only way to reduce TDS is reverse osmosis. Probably should look into a softener though. Hard water sucks.
Sent from my SM-G981V using Tapatalk
Kertin
Hi all. I think the water in my house has too much chlorine (I can smell it, especially when taking a hot shower). What are some inexpensive solutions to the problem?
sdifox
100,868
18,078
err why would there be chlorine in your tap water? you sure it's not chloride?
Kertin
I'm not sure what the correct name is. It smells really strong.
I recently moved in and it wasn't like that in my last apartment.
sdifox
100,868
18,078
Probably chloride, or your water heater has a lot of sediment. Do a water test first.
