Originally posted by: shuttleteam
Find an old (huge) 21"+ CRT that no longer works. Take the guts out and fasten your LCD to the front. Once you're happy with this, remove your TFT and fill the empty space inside the CRT shell with sacks of lead shot. This will weigh 200+ pounds easy. Make sure your TFT is fastened well. You may want to put up a webcam as well. If someone actually does try to steal it, the footage would be a riot!
-DAK-
Originally posted by: SleepyGreggy
Any recommendations on how to secure a 17" panel?
Thanks
Originally posted by: Bleep
you kinda got some good advice a few posts up and that is dont take a lcd get a cheap 17" CRT from staples for under $100.00 they weigh a ton and hard to steal/ do not trust anyone, keep your stuff behind lock and key.
Bleep
-DAK-
I was going to suggest this!
Though for the counterweight, use something that can be removed easier, through a hidden hatch maybe.
Originally posted by: MangoTBG
...Just make sure you don't chain it to a table or chair leg!
I found this out the hardway!
Did they just lift the table and take it?![]()
Originally posted by: abaez
That one with the shrieking alarm would be really good.. with the dorms such close quarters everyone would know something is up.
Originally posted by: Cashmoney995
Ok, this is a real answer...not that the others werent real...but...yea they werent. On the base for the LCD panel drill a couple holes through it and then into your desk. Then use a shiny brass screw and nut to screw it in, tighten hard and somebody will have to have a wrench to get it out. Get an odd size and itll be harder. dont use a wing nut.
Originally posted by: dkozloski
A motion detector and a Claymore mine. Next best is to keep it in a cage with a King Cobra.
the movie swat comes to mind
