What's the best mattress/box springs?
divinemartyr
2,439
I guess since I manage a mattress store (a Mattress Giant store in Plano) I could give a little input here.
From my perspective, no offense RossMAN, but purchasing a mattress from CostCo is sort of like purchasing a computer from a farmer. CostCo's executives who select their product line, probably have no better sense picking out a mattress lineup, than I would developing a new gene therapy for Down's Syndrome or something similar. Most mattresses you find at 'warehouses', or so-called 'factory direct' manufacturers will have 1.0 density foams.
I noticed someone else mentioning you should NEVER buy a pillowtop because it will show a body impression. That's somewhat akin to saying you should never buy a soft-leathered shoe because it will start to conform to your foot and become more comfortable. I'm sorry but I will never purchase a pair of Florsheims or other hard leathered shoe because it's just not comfortable.
With that being said, and having gotten opinions from people as informed as a spinal surgeon, there isn't much better for your back than a pillowtop mattress. Simmons in particular (if you can handle the fact that even most of their softest pillowtops are rather firm) are essentially the best support systems out there due to the fact that they are not based off of an open-coil design. The coils are individually pocketed and the tops can move indepently of the coil next to them. If you like a softer mattress (which some people will, all mattress comfort levels will vary) then try for a Kingsdown or a Chattam and Welles. Chattam is probably one of the priciest mattresses out there (Next to Duxiana) but is probably the most 'comfortable' set I've ever laid on for my particular tastes.
With all that being said, I'll give a little education. Mattress support, or 'firmness' has nothing to do with how the mattress actually feels on top. The support or firmness comes from within. If you get an extremely soft mattress, it also might be one of the most supportive you'll find. There are only 4 ways to make a mattress, and my store carries all of them. It's hard to give coil demos online or I'd give a little more detail.
Also, like some people mentioned, there are mattresses without coils in them now, containing only foams. My personal recommendation is if you go that route, do not buy a tempurpedic. Nothing against the brand, but the foam softens up after about 9 months, and you'll be sleeping in a hole. It will 'bounce' back as it's supposed to but the cellular structure of the foam breaks down. Hence, you can't claim warranty because they will only warranty a product which shows a permanent depression of > 1 1/2".
If you get an all foam mattress, get one which is a combination of latex and memory foam (or visco-elastic foam) so that the latex can provide the support you need over the years. Latex doesn't really break down and will provide great support for 20+ years. We carry one at my store and it's an excellent product. The difference between an all foam mattress and a coiled mattress is the fact that on most any coiled mattress you will toss over between 30-70 times a night, depending on how firm your bed is. The harder it feels up top, the more you will toss. On an all foam mattress which is designed properly, you might only turn 5-7 times a night. This has been proven by a lot of the manufacturers of all foam bedding.
Let me know if I can provide any more tips.
Chad
LeeTJ
4,899
Originally posted by: Crazyfool
Originally posted by: Scarpozzi
Maybe try a temperpedic?
Most matresses are the same, but the best way to find what you like is to go out and look. Not everyone likes a firm mattress or a cushy one. You'll have to try a few out and see what you can afford. Shop around. :p
Yeah, the tempurpedic is best but it's very expensive. Worth it, if you ask me.
Tempurpedic is GOOD, Latex is better. Latex is better cause they have the same level of comfort as the temurpedic but costs a lot less.
I strongly recommend you check out www.mattresses.net
i bought my current mattress, a king size latex mattress, from them and i'm EXTREMELY happy with it. VERY comfortable.
LeeTJ
4,899
Chad
Yo chad
next time your in a mall, check out Florsheim, they have a line of shows called "Comfortechs" that are as comfortable as tennis shoes. VERY nice shoes. that's the only brand i ever wear anymore.
RossMAN
Grand Nagus
Feb 24, 2000
79,089
457
LeeTJ - Which model do you recommend for a Queen sized?
How long have you had yours?
LeeTJ
4,899
Originally posted by: glen
Wow!
Jeraden, you seem to have done your research!
Why not get this one, http://www.mattresses.net/latex-mattress/ , and add in a memory foam topper?
I will try to find Divinemartyr, he is a mattress salesman.
GLEN
that's where i bought my mattress. The PREMIUM Latex mattress i bought from them DOES NOT NEED THE MEMORY FOAM. It's AWESOME as is.
LeeTJ
4,899
Rossman
i've had mine for 2 yrs. it's been AWESOME.
i really really like this bed. also shipping to OR shouldn't be nearly as much as it was shipping to me in NJ. they are based in Arizona if i remember correctly.
www.mattresses.net.
Jeraden
When I said never buy a pillowtop I didn't mean to never have any extra padding on top. What I was saying was, if you want a pillowtop type mattress, just get a normal mattress and get a secondary mattress pad. That way if the mattress pad starts to get worn out after a few years you can just replace it with a new one and make your mattress feel "like new" again. If you get one with a built-in pillowtop and it breaks down/forms permanent impressions, there really isn't much you can do about it. You can put another mattress pad over it, but there will still be that impression in the pillowtop part.
Thx for the recommendation LeeTJ, that helps lessen some of my fears now that I know at least one person is happy with that mattresses.net mattress. I think I'll go with them then.
Mutilator
3,513
10
Bump for lozina
I posted the link in his thread first. :p
Ah it's good to be a subscriber again... only lasted an hour as a non subscriber. Couldn't stand the slower speed, the ads, and the actual forum being 1/2 the size lol. ;)
Oh and the full text searching is nice too. :)
lozina
11,711
8
Bump for lozina
Thanks Mutilator and RossMAN, this thread is proving invaluable. I think I'm now going to order the premium latex mattress =)
RossMAN
Grand Nagus
Feb 24, 2000
79,089
457
From mattress.net?
How much did it cost you including taxes and shipping?
Mutilator
3,513
10
Rossman they have a couple shipping quotes on their site, you just have to look around for them. This is the first one I found:
Shipping cost for your mattress will vary depending on your proximity to Phoenix. - Average cost for a Queen set to New York City is $125, - $145 for a king; (call for an exact price).
No sales tax unless you're in Arizona.
I think I saw somewhere that a king set from AZ to NC would be $179. Obviously they use trucking companies like Roadway instead of UPS or Fedex.
Megamorph
568
I'm about the pull the trigger on the one from mattresses.net. Can anyone else vouche for these?
RossMAN
Grand Nagus
Feb 24, 2000
79,089
457
Send a PM to PlatinumGold he knows a lot about mattress.net's offerings and owns one of their mattresses.
Kung Lau
1,001
After all the reading and researching, I am leaning towards mattress.net also. Anyone else have any experiences?
Megamorph
568
I ordered one from them. It should be here next week. I'll post my thoughts when I receive it.
