No crashes here. Make sure you have Apple updates disabled.
Also make sure sleep is turned off, I had that issue.
For faster scrolling, press right to go from the list of stuff to the scroll bar and then use up or down to go a page at a time. If you hold up or down, it also goes faster, but using the scroll bar is definitely the fastest way (or just typing the letter).
Has anyone else had any problems with XBMC crashing on the ATV2? I tried a couple 720p h264 videos and it crashed anywhere between 30 seconds to a few minutes in. I've heard that XBMC can crash from running out of memory (ATV2 only has.. 256mb I believe) and some apps (like VNC) can really hurt its available memory.
Anyone else with Exposed installed have any problems or could my ATV2 just need a "hard reset" to clear up any possible memory leakage?
I had read a rumor that the next version will have the same CPU as the iPad 2 and output at 1080. If that becomes true and is still at $100 I'll be getting one to take over as my main streaming solution.
Right now I'm using my PS3 and ps3 media server, which honestly works great.
But with the new Cinavia http://en.wikipedia.org/wiki/Cinavia DRM issues on the PS3, it might be getting closer to looking at alternatives. Plus I want a solution that's cheap like this for my bed room and guest rooms.
I might just go ahead and get a current gen now even just for the ability to send content to it from my iPad 2.
If you're still having this issue, make sure you have the newest nightly build.
I just bought two ATV2s and have them setup in the bedrooms. Both are 32inch 720p TVs so the resolution is fine. My dad's watching MLB.TV and we're watching HD downloads. I'm not sure about the earlier comment about slow interface, I think it's quite fast.
For those of you complaining about fanart and posters, you can preset these up and xbmc will use those instead of scraping its own. To do this, I highly recommend Ember Media Manager
