P3-700e has a spec max junction temperature of 80C.  This should be the max temperature (as measured by on die temperature diode) this CPU will function at 700MHz.  There is really nothing wrong with running your CPU at this high temperature unless you are doing extreme overclocking.  In that case, you will want lower temperature to have higher chances of overclocking success.
