What's everyone using for a beard trimmer?
amdhunter
23,332
249
I've had a LOT of them and they all suck. Prices ranged from $10 - $50.
I like the 5AM shadow look, so I want it to get close without having my face looking freshly shaved. (Stubble?)
What's ATOT using?
JulesMaximus
74,587
986
16,996
1,625
What Jules said.
But I got a nice Wahl hair clipper kit at Costco for $30, that had an attachment it said was for beards. If I had a beard, I would probably use that.
BurnItDwn
26,354
1,863
I just use a regular cheap hair clipper. I trim once every month or two these days ... usually keep it around 1/2 to 1 inch long.
Imp
18,828
184
I've gotten board/curious and used my premium hair clippers to try to shave my mustache a few times. Using a 000 (0.5mm?) blade, it doesn't cut anything - mustache too short but not stubble-length short. You'd probably need a 0000 (0.25mm) or 00000 (0.20mm) blade to get stubble length using clippers. For that, you'd need interchangeable metal blades. A 0000 and lower blade usually doesn't come with cheap clippers.
Get an Oster Fast Feed for $60 off Amazon and a 0000 or 00000 blade. Probably about $20 for the blade online. Watch out for razor burn because you're dry-cutting.
Otherwise, there are some cheap Philips "beard groomers" I've never tried.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
I bought a Braun rechargeable with something like seven different attachments. Works very well.
KT
crashtestdummy
2,893
I have this guy. Works really well. My only complaint is that the plastic guide is flimsy and breaks easily in your suitcase. Replacements are reasonably cheap, though.
GobBluth
703
45
I'm actually using the Gillette Fusion ProGlide Styler. I was surprised at how well it works, and for 15 bucks, cant beat it.
z1ggy
10,010
66
What Jules said.
Wahl. Although I've noticed that no matter how hard I clean it and brush out all the hair, it eventually starts to jam up a bit, then eventually useless. I tend to buy a new one @ $40-50 a pop once a year.
Scarpozzi
26,392
1,780
I've had this one for a while.
http://www.amazon.com/Philips-Norelc...s=philips+7300
I used to have a Philips Norelco QT4050 ($39 @ Amazon). I preferred this one because it trimmed more evenly, but I like the digital read out on the length. It just takes quite a few swipes to knock down the thick stubble to get it even.
I need to specify that I got both of those trimmers for $25 or less through promotions from Amazon or Drugstore.com.
smackababy
27,024
79
86
Philips Norelco QT4014/42 is what I use. The lowest setting works just fine for that designer stubble.
tHa ShIzNiT
2,321
8
as I beard owner I 3rd what Mark and Scarpozzi said. Good unit, sucks up (most of) the hair as you trim it.
wabbitslayer
533
I just use a beard that keeps herself up, don't know why you guys are putting so much effort for a pretense nobody believes anyway :rolleyes:
Imp
18,828
184
I shave every other day... It's be every 3 or 4, but my mustache is uneven. So, what's a beard?
