shafty ftw. then again, my motorcycle is a shaft-drive 😉
Isn't a Gilmer belt just a timing belt?
How much torque and how much resistance?
The issue with V-belts of any sort is the potential for slippage. On the other hand, they are quieter than chains and don't require lubrication.
Have you considered a Gilmer belt instead of a V-belt?
ZV
Timing is not essential so slippage will NOT cause malfunction. This would be approx 5hp but could be scaled to a larger (250hp) design.
Belt slippage at start up is anticipated. Since the motor is across the line a chain could be dangerous or just get too loose after a few 100 starts/stops?
I could only imagine the NOISE made when a Gilmor slips! 😱
A V-belt is not a timing belt. This is a timing belt:A Gilmer belt has teeth, a V-belt does not. Because of this, a Gilmer belt won't slip like a V-belt can, which makes it possible to use a Gilmer belt in situations where using a V-belt is inadvisable. They can handle more torque than V-belts but still have the advantage over chains by being quieter and not requiring lubrication. A chain is ultimately stronger, but in most cases a Gilmer belt is plenty strong.
ZV
Well, when the Gilmer belts used as timing belts in my cars slip, it sounds like money flying away. 😱
ZV
http://img.alibaba.com/photo/51281972/Industrial_Timing_Belt.jpg
Don't they just break though? Must suck if you have interference engines!
Now I remember what it sounds like. A screw compactor had one that was jammed and the belt slipped. Sounds like growling and that was probably a 1hp motor!
I'm pretty sure you're the only person alive that would include V-belts as a subset of timing belts. Even stipulating your definition that a timing belt is a belt used for timing, a V-belt simply does not. Cannot.Nope, that's a Gilmer belt. 😛 😉
"Timing belt" technically specifies an application, not a specific type of belt. Theoretically, you could use a V-belt as a timing belt; it would just be a really bad idea.
I rambled more than I should have in my previous answer. Gilmer belts are essentially what are universally used for timing belts, so yes, a Gilmer belt is what people tend to think of when someone uses the phrase "timing belt" colloquially to refer to a type of belt rather than an application. In most automotive engines, Gilmer belts are used for either cam timing or for balance shaft synchronization.
ZV
That compactor should've had a shear coupling.Yes tension becomes a problem as it can wear the bearings too rapidly if too tight and it too loose the belt will start slipping as power ramps up.
Starting is just overcoming dead mass since the pump has to be unloaded.
A pair of 4L belts should be plenty for 5hp or so.
There was a high current limit on the motor but it was jumped out because it kept tripping. 😀
Hydraulic compactors are better but I have to admit the vertical screw method is super simple.
displacement control vs load control. all depends on which one you want 🙂
I've never seen a V-belt used in a non-low-power application, so:
Chain:
+ cheaper
+ lasts longer
+ more space efficient (power transmission density)
- can require maintenance (lubrication, mostly)
- louder
Chains require much more maintenance than belts IMHO. Aside from constant lubrication, chains stretch and require tension adjustment just like belts. However, you also have to account for sprocket wear and they are much less forgiving on alignment.
Depending on the application, a good belt setup (either cog or V) will work fine as long as the belts are properly maintained (tensioned) and the sheaves don't get subjected to excessive wear.
The primary issue with belts (IMHO) is improper maintenance. Sheaves wear out and tend to get "overused", the systems rarely get proper alignment, they are rarely tensioned properly and quite often improperly replaced with unmatched sets or single belts out of a group.
Yes the edges of a sheave should not be so thin they cut like a knife. 😉
