Whats best 12-pipe card?
apoppin
34,890
alienbabeltech.com
even though the agp GS is supposed to be ~$200, it'll still have it's butt handed to it by the $200 [afterMIR] x850xt . . . and that's assuming you can unlock 4 pipes . . .
OP, if you're gonna spend ~$200 on a 12-pipe card . . . ,ight as well get the fastest 16-piper;)
Wolfshanze
767
the gs is basically a 6800gt, wait maybe a little slower due to lower clock speeds then its pci-e counterpart but its still a fast card.
I wish people would stop comparing the AGP 6800GS with the PCI-E 6800GS... yes, I know they have the same name, but they're only related by the NVidia sticker and not much else... the AGP and PCI-E 6800GS cards have completely differant cores and should never be called "counterparts" to each other.
On paper, I'd prefer the 6800GS over the 6800NU, but I'd like to see if the GS has a high success rate (if at all) on unlocking before taking the plunge... I imagine price will have a big deciding factor on which is the better value, but on paper, the 6800GS is definately the better 12-piper of the two.
I won't comment on the ATI cards because I don't really follow that market much, but between the NVidia cards, I'd still recomend the GS over the NU (unless price is a big factor).
Nextman916
1,428
So my best choice seems to be either the 6800gs or the x800gto. If i get a gs i would probably wait for the xfx one that it supposively overclocked, but the agp gto is based of the same n430 core which alows even greater overclocking. The x800pro is becoming alot more expensive now as well as the 6800 so those are out of the question. I would go for the x850xt deal at microcenter however i dont want to deal with rebates, yah it seems stupid but i dont want to.
Wolfshanze
767
I'm sure that card "overclocked" XFX AGP 6800GS is a MYTH not fact. You'll be waiting a long time... the card either doesn't exist at all, or was a typo (350, not 450).
In short, don't hold your breath or be counting on a magical 100MHz overclocked AGP 6800GS... it's just not going to happen. Look at what is on the table now, because that's all there is... a 12-pipe 350MHz 6800GS or the X850XT... there is no "wonder" 6800GS card.
TheRyuu
5,479
14
Originally posted by: jlbenedict
Originally posted by: mwmorph
6800gto2 is fastest(with the guranteed unlock)
6800gs agp(cut down, but there are some good versions, i think xfx is releasing a 450/1.0 version instead of the crap 350/1.0, unlockls but not guranteed, the 6800nu has about a 50/50 chance of unlocking, not too sure about the gs but it should be in that range, being the same hip and all)
X800pro vivo and non vivo(with some work a hardmod to x800xt can be done, 80% chance but reall a hassle, involves taking off the cooler, and using conductive pen on the core, something litk a 80% chance though)
6800nu(just bad, stock, barey faster than a 6600gt, unlocked isnt all that much faster)
Where can I get one of these "6800GTO2's" ??
I think he meant X800GTO2, but lol :p
That would be your best bet, a X800GTO2 flashed to x850xtpe (with 16 pipes), or just go for the X850xt from the start.
EDIT: Wait, is this for AGP? Oh, then just go for x850xt.
chilled
709
Ignore him. There is not GTO2. He may mean the X800GTO2, except that was only for pci-e last time I looked. I would go with the 6800GS as its the only one you'll find in stock!
Edit: Ignore me. I'm a page behind :(
